crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Wi-Fi is Not Working
My tablet does not connect to the internet.
WiFi Switch May Not Be On
Try switching the wireless switch off and on to reset the wireless connection point.
Tablet May Not Be Connected to a Network
An internet connection is needed to be able to use the internet. In order to connect to an available Wi-Fi network, follow these steps:
  • Touch the All Apps icon, and then touch the Settings icon.
  • In the Wireless & Networks section, touch More....
  • Select the Wi-Fi account you want to connect.
  • If needed, enter the pass-code to access the Wi-Fi connection
Front or Rear Camera Not Working
Why won't my front or rear camera work?
Tablet May Need to Be Rebooted
Simultaneously press and hold the power and volume down (-) buttons until the boot menu displays in the top left corner of the screen. Using the volume up (+) and volume down (-) to navigate to the "normal boot" option in the boot menu. Select the normal boot option by clicking the power button and the tablet will reboot.
Camera May Need to Be Replaced
Click the following link to be taken to the camera removal and replacement guide.
Screen is Frozen
Why won't my screen respond to touch or other input?
Tablet May Need to Be Reset
HP Slate 8 Pro Does Not Turn On
Your Android phone or tablet has very few buttons. The only way you can turn it on is by pressing the power button. If that isn't working, don’t panic! There may be a couple of issues you can address to make it work.
Faulty Power Adapter
Check to make sure the power adapter is plugged into a working outlet. If it is, make sure the light on the adapter is on. If the light is not on, and the adapter is plugged in, the adapter is likely faulty. Consider purchasing a replacement adapter.
Faulty Battery
If the adapter is plugged in, and the light on the adapter is on, make sure the adapter is connected to the tablet. If the tablet only powers up when the adapter is plugged in, regardless of charging time, then the battery is faulty and you will need to replace the battery.
Screen is Not Working Correctly
Why is my touchscreen not working?
Dirty Screen
Touch screens are very sensible to the touch. Sometimes dust and skin oils prevent the screen from recognizing touch movements. Clean your screen. To clean a touchscreen, all you really need is a microfiber cloth. For dirtier screens, use a little bit of alcohol along with the microfiber cloth. It is best to use a microfiber cloth because it does not scratch your touch screen while removing all dust and oils.
Can't Hear Audio
Why can't I hear anything from my speakers?
Faulty Speakers
Test audio through the speakers. Make sure the volume is not muted and the volume is turned up, then test it using headphones. If the audio is only distorted while listening via headphones, the audio jack or the headphones themselves may be faulty. If you can't hear through the headphones nor through the speakers, consider replacing your speakers.
Running Out of Memory
I do not have enough memory in my tablet. What can I do?
Replace/Upgrade Memory
You can insert a memory MicroSDHC card slot for memory expansion.
Jose Revelo
crwdns2935283:010/09/14crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Button are showing on the screen and aren't backing.
Sanjay Singh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 6,631
