crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your HP ProBook 640 G3 expelling an excessive amount of heat or the fans are spinning loudly? Use this troubleshooting guide to help diagnose why.
Cooling fan is blocked or damaged
Obstruction of air intake or exhaust can cause a buildup of heat within the system, slowing performance, and eventually causing failure of the device.
  • Take note of the fan grates on the sides and bottom of the laptop, ensure these are not being obstructed by an outside object. Obstructions could include walls, pillows, blankets, etc.
  • Listen to the sound the fan makes, if it’s abnormal, skittering or stuttering, this could suggest damage to the cooling fan properly
Build up of dust
Buildup of dust or other forms of detritus can contribute to inefficacy in the laptop's cooling system, leading to overheating.
  • Find the vents through which the laptop intakes and exhausts the air. If you’re struggling to find them, try to feel where there is a small sucking sensation or a greater amount of heat than normal.
  • Check the vents for an excessive amount of dust or other materials within the vents. Liberal application of compressed air to the affected area should be able to remove the blockage.
Running too many programs
Often, users can end up downloading more programs than they necessarily need. When these programs take up excessive background processing it slows the computer and reduces performance.
  • Power on your device, allowing it to fully run through the bootup procedure until it reaches the home screen.
  • Move the cursor to the lower right-hand corner of the screen, clicking on the upturn arrow button. When doing this a pop-up box should appear, if this box contains more than eight small icons, excessive background processes are likely present.
  • Go into the setting of the device and locate the “Remove Programs” section, here a list of all the programs present on your device will be present. Go through this list deleting anything you don’t recognize, need, or frequently use.
Outdated software
Modern systems frequently have their software updated to ensure performance, among other things. Neglecting these updates could slow performance.
  • When powering down the device, if prompted with a request to update the device, click “Yes”.
  • Open the settings of your device, in the Search Bar, type in “Check for Updates” and press the Enter key. Click the button that says, “Check for Updates”. If an update is available, download it.
Insufficient RAM
RAM memory plays a key role in the performance of the system. If the amount of memory within the system is not adequate to support it, slow performance could occur.
  • Follow the RAM Replacement Guide, hyperlinked here
Battery is defective
A computer battery can last for a long time and can always be recharged, but its physical power degrades over a long period of time. An older battery will need to use more power to maintain necessary power levels, which in turn creates more heat than necessary and more pressure on the system. Replacing a system’s battery is a standard process that can help it from overheating.
  • If you notice a distinct decrease in battery life or a significant jump in performance when the device is plugged in, a replacement may be in order.
  • Follow the Battery Replacement Guide, hyperlinked here
Tej Sai Kakumanu
crwdns2935283:010/15/25crwdne2935283:0
473 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-7, Botvin Fall 2025 crwdns2935289:0UMass Dartmouth, Team 1-7, Botvin Fall 2025crwdne2935289:0
UMASSD-BOTVIN-F25S1G7
crwdns2935297:066crwdne2935297:0
crwdns2942667:0crwdne2942667:0 131
