crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your ProBook feels unusually hot to the touch, shuts down unexpectedly, or the fan runs loudly for prolonged periods of time, follow these steps to identify and fix the overheating issue.
ProBook Is Overheating Due To Blocked Air Vents
Dust and debris can block the device's air vents, trapping heat inside. Check the air vents along the sides, and bottoms of your device.  Use compressed air to remove dust or lint buildup. Always place the device on a hard and level surface to allow for proper air flow.
Learn more about cleaning your ProBook's fan
HP ProBook 455 G7 Fan Replacement
ProBook Is Overheating Because The Fan Is Blocked Or Not Spinning
If the cooling fan is dirty or covered by an object, it can't release heat properly. Make sure nothing is covering the area, such as cloth, paper, or other materials. Keep the back and the sides of the device clear to allow airflow. If the fan itself is clogged with dust, open the back cover and clean it with compressed air, or a soft fluffy brush. Check that the fan spins freely when the device is on. If it's noisy, or slow, or not moving at all, it may need to be replaced.
Learn more about cleaning fans
ProBook Is Overheating Because Thermal Paste Is Old Or Dried-Out
Thermal paste can prevent heat from transferring properly between the CPU and the heatsink. Remove the heatsink, clean off the old thermal paste with isopropyl alcohol, and apply a small amount of new paste before reattaching. Only attempt this if you’re comfortable working with internal components.
Learn more about replacing thermal paste
ProBook Overheating Because There Are Too Many Background Programs Running
Running too many background processors can increase CPU load and heat output. Can open task manager to check for high CPU usage. End unnecessary tasks and disable non-essential startup programs to reduce processor strain and heat generation.
Learn more about managing background apps
ProBook Is Overheating Because of a Hot or Poorly Ventilated Environment
High ambient temperatures make it harder for your device to stay cool. Use your device in a cool, well-ventilated space away from direct sunlight. Keep at least a few inches of space around the vents. For heavy use, consider using a cooling pad to help regulate temperature.
Abeer Zaheer
crwdns2935283:010/15/25crwdne2935283:0
427 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-6, Botvin Fall 2025 crwdns2935289:0UMass Dartmouth, Team 1-6, Botvin Fall 2025crwdne2935289:0
UMASSD-BOTVIN-F25S1G6
crwdns2942667:0crwdne2942667:0 213
