The computer doesn't start
I have the charger plugged in and I'm pressing the power button, but the computer still won't start.
Short circuit
Try to wiggle the power button around, you may have accidentally pushed it into a shorted position.
Too much information in memory
You may need to reset the connection between BIOS and the hardware try performing a hard reset on your computer. You can do this by removing the battery, power adapter and pressing on the power button for a minute. Reattach the power adapter and then the battery and try to start it.
Drained/dead battery
If your charger is plugged in and the computer still will not turn on your battery may need to be replaced.
The computer restarts without command after extended use
When I use my computer for a long time, it restarts without any warning.
Overheating
Make sure your air vents are clean and unobstructed and your fan is working properly, your computer may be overheating.
Bad logic board
If your computer immediately turns off, after being turned on then it is likely you have a faulty logic board.
There is no sound coming from the speakers
I'm not getting any sound coming from my speakers.
Update the audio driver
If you've recently upgraded to the Windows 8 or you're experiencing the problem in a software program, then you may need to update your audio driver.
Bad logic board
Try to do a recovery, if the problem persists then it's most likely the logic board.
I hear a high pitched buzzing sound
My computer is making a high pitched buzzing/humming sound while it's running.
Change Power Configuration
You may need to change your power scheme, this is because the capacitors in your PC may be resonating at your current power setting causing them to produce an audible sound.
You can adjust the power settings by going through Start > Control Panel > Power Options. Settings like "Portable/Laptop" and "Max Battery" should solve your problem.
I keep getting this error: "HP MediaSmart TV Resident Program has stopped working"
I get this "HP MediaSmart TV error after I restart my computer."
Update HP MediaSmart TV software
There may be a newer version of HP MediaSmart TV software, so if you haven't updated the software you need to do so.
Erik Muniz
crwdns2935283:009/09/14crwdne2935283:0
847 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-3, Bruce Fall 2014 crwdns2935289:0CSU Fullerton, Team 2-3, Bruce Fall 2014crwdne2935289:0
CSUF-BRUCE-F14S2G3
crwdns2935297:036crwdne2935297:0
crwdns2944067:04crwdne2944067:0
No display.technician says graphics card damaged.replace?please advise
Ramakrishna - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same situation. Hope someone answers us :(.
Erik Knudsen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
So I've had this computer since I was 17. I'm 26. This thing has been great. YES, it's not good for video games but great for everything else.
Recently, the screen stopped showing anything for me. I've tried hard-reseting it, letting it die, then charging it, and turning it back on, turning it on and letting it run for a few hours (to just see if it's spending time loading), and this thing's f#cked. I need help! Any light bulbs or replacements I need to know about?
I've dropped a pc before. You can't see the screen. You see color lines of about a half centimeter going across the screen. You can't recognize anything. Well, I didn't drop it, but this is what I see. Is there a way to reboot ?
Gregory Watson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 4,008
