crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your HP 250 G7 becoming unusually hot during use, causing performance slowdown or random shut downs? Use this troubleshooting guide to help diagnose why.
Dust Buildup in the Cooling System
Over time, dust can accumulate inside the HP 250 G7’s vents and fan, restricting airflow and causing the laptop to overheat. When the airflow is blocked it causes the internal components including the CPU to run hotter than intended.
  • Use compressed air to blow dust out of the vents.
  • If the laptop continues to overheat, you may need to open the bottom cover and clean the fan directly.
  • Follow the HP 250 G7 Fan Cleaning or Fan Replacement guide for step‑by‑step instructions. Fan - HP 250 G7 Maintenance And Service Manual [Page 59 | ManualsLib|new_window=true]
Failing Cooling Fan
A worn‑out or damaged fan may spin slowly, make grinding noises, or stop working entirely. Without proper fan operation, the laptop will overheat quickly.
  • Listen for unusual sounds and check whether air is blowing through the vents.
  • If the fan is not functioning the correct way then it must be replaced
  • Follow the HP 250 G7 Fan Replacement guide for detailed steps .Fan - HP 250 G7 Maintenance And Service Manual [Page 59 | ManualsLib|new_window=true]
Blocked Vents or Poor Ventilation
If the laptop is used on surfaces that are soft like blankets, beds, or a couch. The bottom vent can become blocked, preventing good airflow and causing the computer to overheat.
  • Always place the laptop on a hard, flat surface to allow air to circulate.
  • If overheating stops when the laptop is moved to a better surface, ventilation was the cause.
Background Apps Draining the Battery
Applications that are running in the background can overwork your laptop. Especially browser tabs, startup programs, and background processes which drain the battery quickly.
  • Open Task Manager and close unnecessary apps.
  • Disable unneeded startup programs to reduce unnecessary background activity.
  • If temperature improves after closing these programs, excessive background activity was the cause.
Erik Romo
crwdns2935283:003/11/26crwdne2935283:0
549 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team 8-13, Dieterle Spring 2026 crwdns2935289:0Purdue University Northwest, Team 8-13, Dieterle Spring 2026crwdne2935289:0
PNW-DIETERLE-S26S8G13
crwdns2942667:0crwdne2942667:0 135
