crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If you press and/or hold the "on" button on your HMD Barbie Phone, but it does not result in the screen turning on, follow this page for possible solutions.
Device needs to be restarted
Hold down the "end call" button (the bottom left of the top portion of the keyboard) to power the phone off. Wait 30 seconds, then hold down the "end call" button for 3 seconds to power it on.
Battery is damaged or is not in device correctly
Remove the phone's back plate by applying force and sliding it down. Remove the battery. Ensure there is no swelling or physical damage to the battery. If swelling or physical damage is present, do not continue to use the battery. If no swelling or physical damage is present, put the battery back in, ensuring it is properly aligned. Put the back plate back on and attempt to power on the phone.
Battery is dead
Use the power cord and charging brick that came with the phone to charge the phone. Let the device charge for 5-10 minutes, then attempt to power on.
Charging cord or power brick is faulty
Use a different USB-C cord with the same charging brick to charge the phone for 5-10 minutes, then attempt to power on. If this doesn't work, change out the charging brick for another 5-Watt charging brick. Allow the device to charge for 5-10 minutes, then attempt to power on.
Video ribbon is disconnected or damaged
If the phone screen does not turn on, but phone sounds are audible, the video ribbon may be damaged or disconnected. See this guide on locating and reconnecting or replacing the video ribbon.
Motherboard is broken
If the phone still does not turn on after verifying that the video ribbon is intact and attached, the motherboard may need to be replaced. Follow this guide to replace the motherboard.
Hannah Carvalho
crwdns2935283:003/09/26crwdne2935283:0
571 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-2, Botvin Spring 2026 crwdns2935289:0UMass Dartmouth, Team 6-2, Botvin Spring 2026crwdne2935289:0
UMASSD-BOTVIN-S26S6G2
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 336
