crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Feed blade doesn't move properly
Feed blade doesn't move back and forth as it should
Parts need oiling
The blade may just be insufficiently lubricated. To fix this simply apply some oil to [crwdns2936915:0crwdne2936915:0].
No template in place
Open the template retainer plate to check to see if there is a template in place. If there is no template then simply select one that should have come with the device and [crwdns2936915:0crwdne2936915:0].
Template won’t stay in place
The template doesn't seem to always work
Template retainer plate is broken
Upon opening the template container, there should be a metal piece slightly sticking up. If it’s not, try to lift it back up. If it’s missing try placing something such as a piece of cardboard .3cm thick to help keep it in place.
Lock on template retainer plate is broken
There should be a small piece of metal protruding from the bottom. If it’s there, make sure it’s not bent. If it’s not there, try to glue something in its place that's .4cm by .2cm by .1cm.
Can’t adjust the size of the stitching ring
Something is wrong with the size of the buttonholes
The size adjuster isn't moving
The size adjuster lever could be stuck. [crwdns2936915:0crwdne2936915:0] and check to see if there’s something keeping it stuck in place.
Spring on fork arm is broken/missing
There should be a spring that connects to the fork arm. If it’s broken or missing , turning the knob causes the device to go in a line rather than an oval pattern. Try [crwdns2936915:0crwdne2936915:0] the spring.
Knob won’t stay in place
The main knob wobbles around
Knob is not properly screwed in
The knob could simply [crwdns2936915:0crwdne2936915:0]. Try to push down and turn it clockwise until you start hearing a clicking noise. If it’s clicking but still wobbling, there might be another problem.
Screw is stripped
Take out the knob but turning it counterclockwise. If the screw appears to be missing its ridges you can try ordering a replacement for it.
Spring is missing
The knob should have a spring wrapped around the screw. This helps connect the knob to the device. If it is missing, you could try ordering a replacement for it.
Michael Sykes
crwdns2935283:010/06/14crwdne2935283:0
552 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-6, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 3-6, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S3G6
This is a good site, but I do not know the terms for parts. Pictures needed!
aledra - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 704
