crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Audio Interference
Move location of device away from other appliances or obstructions. Make sure your Google home is in a quiet location and try speaking loudly and clearly.
Microphone is Muted
The microphone of your Google home may be muted (if this is the case there will be four still, orange lights in a diamond). To unmute your Google Home press the button on the back of the speaker.
Google Home is Slow or Buggy
Try restarting your device. Open Google Home app and select the device you are trying to reboot. Go to Settings (three vertical dots in the upper right corner of the device card) and tap More and then Reboot.
or
Unplug the device for roughly a minute, and then it plug back into the power source. Allow the device to reboot itself.
Google Home not Recording Correctly
Go to myactivity.google.com and listen to the voice recordings that your device is picking up. If you hear static or bad quality recordings contact Google Home Support. The "Contact Us" option will be in the upper right hand corner of this page.
Operating System Bogged Down By Existing Data
Your Google Home may need a complete reset to default factory settings in order to fix the issue. This action cannot be undone and you’ll need to set up the device again.
If nothing else is working: press and hold the mute button on the back of your Google Home for about 15 seconds. You'll hear your Google Assistant confirm that it's resetting Google Home.
crwdns2935291:0crwdne2935291:0
Gabe Hyun
crwdns2935283:004/17/18crwdne2935283:0
847 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S24-G11, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S24-G11, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S24G11
crwdns2936753:030crwdne2936753:0 64
crwdns2959996:0crwdne2959996:0 1,572
