crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Google Home is too Close to Wi-Fi Source
Your Google Home does not stay connected when it is placed right next to the source of Wifi. Move it away from router and modem to keep the connection.
If it still does not stay connected to the wifi, restart router and modem.
Issue with Wi-Fi Source
The source of the wi-fi network may be the issue. Check to see if other devices are connected and successfully using the wi-fi; if not, you may need to restart router and modem.
Google Home is Slow or Buggy
Try restarting your device. Open the Google Home app and select the device you are trying to reboot. Go to Settings (three vertical dots in the upper right corner of the device card) and tap More and then Reboot.
or
Unplug the device for roughly a minute, and then it plug back into the power source. Allow the device to reboot itself.
crwdns2935291:0crwdne2935291:0
Gabe Hyun
crwdns2935283:004/17/18crwdne2935283:0
847 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S24-G11, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S24-G11, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S24G11
crwdns2936753:030crwdne2936753:0 66
crwdns2959996:0crwdne2959996:0 929
