crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Will Not Turn On
The drone or controller will not respond or show any sign of powering up.
Faulty Power Adapter
Ensure everything is plugged in, and observe which charging lights come on. If all lights appear on (controller, adapter, and battery), then the charging system is complete.
If not all lights are on, determine which component is problematic (if a component does not work properly, the charging light will not turn on when plugged in) and consider replacing the faulty component with a new one.
Faulty Battery
Remove the main battery from the GoPro Karma drone, then make sure that there is nothing blocking the battery from making a connection to the drone when attached. After, ensure the main battery is plugged into the adapter. If the light is still off, consider purchasing a replacement.
Faulty Controller
Ensure the controller is plugged into the adaptor. If the light is still off, try other USB-C cords. If it still will not power on consider purchasing a replacement.
Sudden Loss of Power
The drone loses power before take off or during flight.
Battery Disengagement
GoPro has issued a recall for the Karma, so you can get a refund if you experience this problem. If you would like to still keep your current drone, a quick fix is to put a large piece of tape over the battery to firmly attach it in the drone body.
Wire Connectivity Issue
Ensure that all wires/connection locations between the battery and the main board aren’t broken, and ensure that there is contact between the metal surfaces of said components.
Controller not connecting
The controller will not pair with the drone.
Not Turned On
Make sure that the GoPro controller is turned on so that the drone is able to connect.
Out of Range
Ensure that the controller is in range of the drone so that the connection is not lost. If the drone is approaching limit range, it will notify you; make sure to be aware when flying the drone.
Drone Not Taking Off
The drone will not initiate the take off sequence.
Foreign Substance Jamming Rotary Component
Ensure that rotors can rotate cleanly without being blocked by a foreign substance. Small pieces of debris may often times get stuck in the rotors, and prevent the drone from getting any lift. Make sure to clean your device to obtain proper performance parameters.
Drone Not Tracking
The drone will not stay in the intended shot location
Updated Software
Stay up to date on the most recent software updates to ensure that your drone and controller are compatible and working with the greatest efficiency possible.
Unobstructed Wireless Connectivity
Ensure that there are no foreign obstructions in the way of the infrared connection between the drone and the controller. The drone cannot properly function to the user’s preference if it cannot receive a connection from the controller. Fly the drone in open areas and within range.
Jay Ingram
crwdns2935283:004/19/18crwdne2935283:0
334 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S25-G14, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S25-G14, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S25G14
crwdns2944067:011crwdne2944067:0
I have a problem with the settings icon.When I tap on it,it will go to options and then go back to the icon again and sometimes dont even do that.
Sal Rennie - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi
Goodafternoon .my karma drone doesnt power on and i dont know how could i make it work properly thank you
Sincerly yours hamid
Hamid - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Good day my karma drone power not and the battery are full. The light are on
I have no idea how I can fixed it can someone help my
Ruud - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My karma can not connect with controller, pls help me
Nhan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I try to calibrate the screen says no gps, what can I do?
Todd Sipe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 64
crwdns2959996:0crwdne2959996:0 9,769
