crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
GoPro won't turn on
No matter what you do, you can't get your GoPro to turn on.
Malfunctioning battery
On the back of the GoPro remove the back cover by pressing the switch in. Remove the battery and then reinsert. Attempt to turn GoPro on.
Drained/bad battery
If your GoPro will not turn on, try plugging the charging cable into the GoPro to charge the battery.
GoPro freezes and will not record video
You're about to take an epic, underwater shot in the Antarctic when you realize that your GoPro is frozen.
Camera firmware glitch
To reset the camera, press and hold the MODE button for 10 seconds. Release the button and the camera will reset.
Malfunctioning Battery
Outdated camera firmware
Visit GoPro's website to download the most recent update. Follow the instructions provided to complete the installation of the new firmware.
Camera stops recording
Right in the middle of capturing the most incredible shot, your GoPro stops recording.
On the back of the GoPro remove the back cover by pressing the switch in. Removed the battery and then reinsert. Attempt to turn GoPro on.
SD card formatted incorrectly
Delete all the files on the SD card and then insert into the GoPro. The GoPro will then reformat the card.
SD card "err" (error) message
You're about to film the perfect video when you realize your GoPro has an error.
This usually is caused by the card being formatted to a separate device. To begin, delete all files from the micro sd card. The GoPro will reformat it so that it may operate correctly.
Faulty micro SD card
If the camera still displays the “err” after being formatted then the issue may be with the card. The micro sd card may not be compatible with the GoPro. In this case you must begin looking to troubleshoot the micro sd card. Lastly, if the card has been correctly formatted to the GoPro then “DCIM” and “MISC” should be displayed as folders on the micro sd card.
Wireless not connecting to smartphone
Camera needs troubleshooting
If your camera will not connect to your smartphone wirelessly, then you can troubleshoot this by going to the settings menu (picture of a wrench), then to wireless controls (picture of a sun). Then find the “Wi-Fi RC” tab and select “current” or “new connection.” A blue light should turn on or flash to assure you it is connected to WiFi.
GoPro app issues
If you issue is associated with the GoPro app on the smartphone, then it is most likely not yet compatible. On December 14th a release is set that will allow this connection. If this does not solve the problem then follow the above directions and do what the app tells you to do when the camera cannot be found.
Additional Information
GoPro Hero3+ Repair Section
GoPro Hero3+ Silver Edition: Review
GoPro Hero3+ Silver Edition: Video Teardown
Patrick Cook
crwdns2935283:010/01/15crwdne2935283:0
699 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-8, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-8, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G8
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 2,514
