crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Computer Doesn’t Turn On
The laptop will not respond or show any signs of of turning on when power button is pressed
Faulty Battery
If you have have plug in your adapter and there is a light but your computer only stays on as long as it plug in you should replace the battery.
Faulty Power Adapter
If there is no light showing where the battery symbol is shown then you will need to replace the adapter.
Keyboard/Key Not Working
Certain or all keys are not performing their designated function.
Debris Under Keys
If you press onto a key and it doesn't go down there maybe something stuck under the keypad. You will need to use your finger or other small tool to gently lift the cap off of the key and access the area below it. Gently wipe the key to remove any debris and put the cap back on the key. If you would like to avoid removing keys you can attempt to clean below it using an aerosol duster spray with an extended nozzle.
Keys Are Missing
If there are any keys missing from the keyboard then you will need to replace the missing keys using this guide.
Ribbon Cable Disconnect
The keyboard ribbon cable may have disconnected. To reconnect it you must reconnect the ribbon cable.
Computer Shutting Down During Operation
Computer crashes while performing tasks without battery dying.
Not Enough RAM
If you notice that your computer is crashing during normal operation or during a memory task or beeps at you and will not boot up this means that you have a bad ram or that you don't have enough RAM. Therefore you will want to install a higher tier RAM onto your computer.
Hard Drive Error
This could happen if the user is shutting down the computer by holding down the power button instead of using the shutdown sequence. To fix this use a Windows dvd for the appropriate the version of Windows on your computer. Boot the DVD and choose ->repair your computer -> next -> startup repair. This should fix the issue that you were having if not then you will need to replace your hard drive.
Computer Not Able to Start Up Certain Files
Computer will not run certain programs.
Program Error
If you go to download something or try to run a program and you get a error code it is possible you are missing certain components to use said program. Usually the error will tell you what you don't have therefore you will need to uninstall and reinstall the program or download the missing pieces.
Computer Error
If you still see or have issue with said program then you should take your computer into a store that works on computer or you will need to wipe your computer and reboot everything. If that is the case make sure you have everything that you want to keep storage in a flash drive so you don't lose it.
Computer is Overheating
Computer feels extremely hot.
Debris in Vents
If your computer is overheating over simple program running you might want to check your fan vents to make sure there isn't anything blocking the vets. Simply take a cloth or a small q-tip and gentle wipe any dust or anything that may be causing the issue.
Cooling System Malfunction
If the problem still continues while using the computer then you will want to take your computer in to get checked out because the longer you let it go like that the more harm it could do to your computer.
Touchpad is Unresponsive
Unable to Navigate on your Device by Using the Touchpad.
Touchpad Disabled
To enable your touchpad on the device use a Fn key plus a function key in order to check if the touchpad is disabled. If these steps do not work then it would be beneficial to attach an external mouse in order to navigate through your device to the touchpad properties.
Kelsey Rodrigues
crwdns2935283:010/23/18crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G1, Simcock Fall 2018 crwdns2935289:0UMass Dartmouth, Team S1-G1, Simcock Fall 2018crwdne2935289:0
UMASSD-SIMCOCK-F18S1G1
J’ai un gateway n252214u, quand je presse sur le bouton démarrage la LED demarrage s’allume et s'éteint simultanément, l'ordinateur ne s'allume pas. J'ai déjà changé les modules RAM, rien ne marche. Alors, que dois-je faire, vue que c'est une panne de courant.
Samuel Nelson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, I have the same type of this computer, Gateway NE52214u, when I press the start button, the LED blinks and disappears, no movement, the computer does not start. I changed the RAM modules, nothing works, I don't know what to do now.
crwdns2942667:0crwdne2942667:0 703
