crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If the power button is pressed on the Garmin Nuvi 2559, and the screen will not light up even when it is plugged in, follow this page for possible solutions.
Faulty Charger or Wire
Ensure the power adapter is fully plugged into the device and the wall. Inspect the charging cable and adapter for any visible damage, fraying, or bent connectors. Test the cable on another Garmin device if available. Make sure the charger is working properly by using another device with the same USB type. If the charger is not working, replace the charger.
Power Button is Stuck or Malfunctioning
Examine the power button for debris, dirt, or signs of physical damage. Gently press and release the button multiple times to loosen it if it’s stuck. If still unresponsive, perform a soft reset by pressing and holding the power button for up to 30 seconds while connected to power. If there is no response, the button assembly may need professional repair or replacement.
Battery is Fully Drained or Not Charging
Connect the device to a power source that is certainly working using the original Garmin charger. Let the device charge for 30 minutes before powering on. Hold the power button for about 15 seconds to complete a reset. If it still doesn’t power on, try a different charging cable and outlet to make sure the issue isn’t with the power supply.
