crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Battery is draining quickly
The battery is draining much faster than it should.
High display brightness
Screen brightness has a large effect on your battery. When possible, keep your display brightness to a minimum to conserve battery life.
Battery settings not optimal
There are a couple of things that you can adjust in settings that can maximize battery life. Try enabling battery save mode, turning on the auto sleep feature, and turning off the Bluetooth wireless feature. One or all of these things should help to increase your battery life.
Old battery
If your battery life has not improved after trying the suggestions above, it could be because you have an old battery. To fix this problem, you should replace the battery using this guide.
Screen is Black
The screen is not turning on when the user presses the power button.
No charge
Your device may be out of battery. Pull back the weather cap at the bottom of the device and attach the power cord into the USB port. Plug the larger end of the USB into the AC adaptor or computer USB port.
Device needs to be reset
If you find your device is stalled and not responding, a hard reset may need to be performed. To do this, hold down the power button for 10 seconds. Device will be restarted promptly.
Charger is faulty
The charger for the Edge 830 may be faulty. Try using the same cord to charge that uses the same USB port to verify it is restoring power to a familiar device. If the familiar device is not charging, it is likely that you need to purchase a new cord.
Battery is faulty
Plug the Garmin Edge 830 into a functioning power cord. If the device is unable to hold a charge the battery may need to be replaced.
Phone Bluetooth will not Pair
The Bluetooth symbol does not appear and the mobile device does not show it is connected to Garmin EDGE 830.
Bluetooth is Not Enabled:
The Garmin EDGE 830 can’t connect to your mobile device if you don’t allow it! Verify that the bluetooth connection setting is (enabled).
*Also confirm that the bluetooth connection setting on your individual mobile device is enabled as well!*
Bluetooth Connection is already Paired to Another Device
The Navigation device only has the ability to connect to one device at a time.  Access the settings on the Garmin EDGE 830 and verify that any other devices have been disconnected.  Once confirmed, try to reconnect your device.
*Once bluetooth connected, you can save your device on the Garmin EDGE 830 as friendly devices*
Device is in the incorrect language
My device is not in the desired language, and I am unable to decipher the words.
Incorrect Language Settings
Navigate to settings marked by the symbol of three horizontal lines. Select the last item in the list of setting options. Within these next set of options, select the seventh option offered. In order to read the device, you must select the desired language.
Directions not exact to current location
My device is not picking up my current location.
Compass is not calibrated
Preface:  *Calibrate the electronic compass outdoors.  Please do not stand near objects that influence magnetic fields.  Ex: Vehicles, buildings, overhead power lines.*
Navigate to the setting page on the Garmin EDGE 830, symbolized by three horizontal lines. Access the systems page within the setting menu. While on the systems page, select Calibrate Compass.  Then follow the on-screen instructions for recalibration.
Incorrect Elevation Level
If your device is not displaying an accurate elevation level, navigate to the symbol of three horizontal lines and select Set Elevation. Enter the accurate elevation data for your current location and select the check mark. (Desired language).
crwdns2935291:0crwdne2935291:0
Samantha Klopman
crwdns2935283:003/21/22crwdne2935283:0
293 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 3-2, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 3-2, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S3G2
crwdns2936753:030crwdne2936753:0 87
crwdns2959996:0crwdne2959996:0 5,682
