crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Unable to pick up GPS signals
When using the device it doesn’t pick up routing information
Device has not been updated
Before using the device you should make sure you sync the device to your Garmin Connect account. If this step hasn’t been completed, then the device has not got the chance to download several days of satellite data and will cause GPS issues. Connect the device with a USB to the computer and begin to sync the device to you Garmin Connect mobile app using your Bluetooth enable smartphone. While connected to your Garmin Connect account the device downloads satellite data, allowing it to quickly locate satellite signals.
Device will not turn on
Device will either not turn not, or not stay powered on.
Faulty Power Button
If the power button has fallen off, or fails to power on the device, try replacing it.
Minimal battery life
If the battery is draining quickly, try one of the following: Minimize back light, disconnect Bluetooth, and turn on auto sleep. If the battery continues to drain quickly, replace the battery by following this guide here.
Randomly powers off
If the device randomly shuts down, follow this guide here to replace the battery.
Device will not charge
When plugging Garmin edge 1000, the device does not register the power supply.
Faulty USB cable
If the device does not charge when plugged into a USB cable, try plugging the device into a different USB cable. Also, ensure that the USB cable is completely plugged into the Edge 1000, as well as a wall charging port.
Faulty Charging port
If a faulty USB cable has been ruled out, replace the charging port.
Russell Webster
crwdns2935283:010/03/19crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Eastern Washington University, Team S1-G2, Al-Hmeyrat Fall 2019 crwdns2935289:0Eastern Washington University, Team S1-G2, Al-Hmeyrat Fall 2019crwdne2935289:0
EWU-AL-HMEYRAT-F19S1G2
crwdns2935297:048crwdne2935297:0
After upgrade 15.30 cant pair edge with my Galaxy Note 10 plus
tagteam91 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This spring , speed seems to jump. No change in my speed. Has always been consistent in past years. Will go from 12.8 to 7, 14 to 9, 10 to 6 etc. Any thoughts?
Brian D Humphrey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Dear team, rain got inside my Edge 1000 and it stopped working, after the screen dimmed. Where shall I start to fix it? Thanks.
Victor Neto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 4,866
