crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Garmin Dash Cam 35 is not turning on when holding the power button, follow these steps to troubleshoot the issue.
Faulty Buttons
  • Hold down the power button for 20 seconds to determine if the device will respond.
  • Try pressing other buttons to check whether the issue is isolated to a single button or all the buttons.
Insufficient Power
  • Plug the device into a direct source of power rather than a vehicle power outlet.
    • Try two different cables to this source of power.
  • Try another independent source of power, such as a computer or wall outlet.
    • Try two different cables for this source as well.
Damaged or Blocked USB Port
  • Look inside the port for dust, debris, or corrosion that may prevent proper contact,
  • Visually inspect the port to see if any internal prongs are broken or bent.
Faulty microSD Card
  • Remove the microSD card and attempt to power the device on without it.
  • Try a different, known working microSD card to rule out card corruption as the cause.
    • Ensure the replacement card meets Garmin's speed and size requirements.
Software Errors
  • If any button responds intermittently, attempt a soft reset by holding the power button until the device restarts.
  • If available, use the in-menu reset options to clear any temporary software errors without deleting the recording.
Nic Grout
crwdns2935283:010/20/25crwdne2935283:0
123 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team 3-2, Dieterle Fall 2025 crwdns2935289:0Purdue University Northwest, Team 3-2, Dieterle Fall 2025crwdne2935289:0
PNW-DIETERLE-F25S3G2
crwdns2959996:0crwdne2959996:0 204
