crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Will Not Turn On
When users try to switch on the device, nothing happens.
Dead Battery
If the charger is plugged in but the device still doesn't response, then the battery is not working. Consider changing the battery.
Faulty Charger
If there is no USB inserted sound when charger is plugged in to the computer, the charger is not working. Consider purchasing a replacement charger.
Sometimes Can't Charge the Device
After using few months, the charging port is not sensitive.
Rusty or Oily of Contact Surface
The contact surface might be rusty or oily because of being used. Dripping few drops of alcoholic cleaner on tissue and cleaning the charger port might help.
Inaccurate Result
Device can't detect the accurate distance after hitting the golf.
Faulty Odometer
If the device can't measure the actual distance, the odometer is faulty. Need to replace a new odometer.
No Satellite Signal
The device can't connect to satellite.
Weak Satellite Spots
It might be due to too many shelters or user is staying in in-door where the device cannot detect the signal. Users can try to go out-door or somewhere spacious to try the device again.
Faulty GPS Receiver
If the user is locating on a golf course but the device is still unable to connect to satellite, then the GPS receiver is faulty. The user needs to replace a new GPS receiver.
No Particular Golf Course Is Found
The device can't search the nearby golf course.
Outdated Version of the Operational System or Maps
If the user can't find the nearby golf course, it might be due to the outdated version of system. Go to the Garmin website to download the newest version of OS or maps.
Abdulah Al Alhareth
crwdns2935283:002/15/16crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
IUPUI, Team 10-10, Wilson Spring 2016 crwdns2935289:0IUPUI, Team 10-10, Wilson Spring 2016crwdne2935289:0
IUPUI-WILSON-S16S10G10
crwdns2944067:053crwdne2944067:0
S2 will only take half a charge bought a new clip but the same
Ian Hall - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same issue. I plugged the S2 in for hours, but the Garmin message would flash on the device for a second and go away. I then plugged it into a computer and got the watch to respond. I updated the software, as suggested. But now it says it’s charging, but only charges 1/2 way.
Very disappointed.
johnnyt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
S2 can't be recognized by my computer although I use the USB adaptor. Disappointment only after 18 months.
alain fortier - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the exact same problem. The watch works fine, but I cannot get it to sync to my computer. So I can’t update the golf courses or upload my scores. Very disappointed.
Steve Harlow - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My S2 will not take a charge. I have had it just over 2 years I’m disappointed I did clean it bout it still is not charging!
smstudley - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 50
crwdns2959996:0crwdne2959996:0 44,811
