crwdns2862674:0crwdne2862674:0
This wiki page is a stub. Help us improve this page by adding information to it!
crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Can't switch to other system
  1. Make sure power cord is plugged in.
  2. Make sure AV cable is plugged in to the device and the TV.
  3. Check if button is jammed.
  4. Make sure channel switch is toggled to the same channel as the TV.
  5. Make sure your game system works.
  6. Make sure correct system is selected.
  7. If none of these suggestions works, consult a repair guide.
System won't display when switched to
  2. Make sure TV is on and set to the same channel as the channel switch on the device.
  3. Make sure the correct system is selected.
  4. If none of these suggestions works, consult a repair guide.
TV won't display
  1. AV cord isn't plugged in.
  2. Make sure AV cord isn't damaged.
  3. TV isn't set to the same channel as the channel switch on the device.
  4. TV cable isn't plugged in (RF only).
  5. TV switch is tuned to TV on device (RF only).
  6. If none of these suggestions works, consult a repair guide.
Device isn't receiving power
  1. Check if power supply is plugged in.
  2. Check if power supply is damaged.
  3. If none of these suggestions works, consult a repair guide.
Button is jammed or won't assume the off position
  1. Try pushing on another button.
  2. If all buttons are pushed in, push hard on any one button.
JustinL
crwdns2935283:010/20/13crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
UMass Dartmouth, Team 4-6, Vijaybhaskar Fall 2013 crwdns2935289:0UMass Dartmouth, Team 4-6, Vijaybhaskar Fall 2013crwdne2935289:0
UMASSD-VIJAYBHASKAR-F13S4G6
crwdns2942667:0crwdne2942667:0 732
