This code indicates a problem with the Electronic Range Control/Electronic Oven Control (ERC/EOC).
The Basics
Disconnect Power
As with almost any error code, resetting the device is a good first step. For GE ovens, the easiest way to do this is to disconnect the power.
  • You may be able to reach the plug on gas or electric ranges or stoves. You can disconnect the power at the circuit breaker if it is difficult to reach.
  • Built-in ovens (like wall ovens) require you to disconnect power at the circuit breaker since they are usually hardwired and don't have a plug.
  • Leave the power disconnected for 5 minutes.
  • Reconnect the power and check to see if the error returns.
  • If it does, move on to the next item.
ERC/EOC Failure
The F5 Code is caused by a failure in the EOC, which concerns supervisory circuits. The ERC/EOC must be replaced.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
40 276 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:086 246crwdne2935297:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 1,180
