crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Refrigerator Door will not open
Range of motion of door is restricted
Due to the location of the refrigerator, check to make sure there are no objects that may prevent the door from fully opening. Consider reversing the swing of the door. Reverse the door using this guide.
Hinges are rusted/loud
Check to make sure that the seal protecting the hinges is still properly protecting them. Try applying WD-40 to both hinges. If this does not work, consider buying and replacing the hinges. Replace the hinges using this guide.
Refrigerator is not level
Check to make sure that the floor the refrigerator is standing on is level. If the floor is uneven, consider readjusting the feet of the refrigerator to maintain a level surface.
Refrigerator isn’t staying cold
Gasket is loose or falling off
Check to make sure that the gasket is tight and not falling off. Try popping the gasket back into place. If gasket is damaged, consider replacing it with a new one.
Refrigerant is low or leaking
Check to make sure that the door and gasket are both tight and keeping the cool air in. If the refrigerator is still cold, consider checking the refrigerant and possibly replacing it.
Dust in vents or fan
Make sure that the core temperature is already recalibrated, if still not cold, check the vents or fans. Consider moving refrigerator away from walls to easily clean the vents.
Peterluchini
crwdns2935283:011/05/15crwdne2935283:0
568 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-2, Bhusal Fall 2015crwdne2935289:0
UMASSD-BHUSAL-F15S1G2
crwdns2935297:036crwdne2935297:0
crwdns2944067:04crwdne2944067:0
We have the opportunity to buy four of these, repair them and resell them. I need to know if they can be recharged with Freon?
Cher Carter - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
what's worse is if you don't heat the condenser in a freezer
Percival Villapa - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have this model and it stopped working. The motor doesn’t sound like it’s running at all. It isn’t cooling anything. I turned the thermostat to the coldest temperature and still nothing. The only thing that appears to be working is the light inside. Any advice or videos that may be helpful?
Becca G - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
سلام یخچال و فریزر ساید فریجیدیر قسمت فریزر خوب کار میکند ولی در قسمت یخچال دمپر یخچال باز نمیشه و یخچال سرد نمیکنه علت از چی میتونه باشه
Mostafa taher - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,164
