crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Buttons Not Responding
Buttons are not moving when you press them.
Buttons Are Stuck in Place
There could be debris in the way of the button’s movements, including dirt, water, or sand. To fix this, try taking the watch harness apart and putting it back together using this guide XXXXX. Then you can clean around the buttons to make sure any debris is out of the way using a q-tip. If it needs to be re-oiled to provide a smoother motion you could do that as well.
Buttons Are Tightly Held Together
It is also possible that the spaces in between the harness and the buttons are too tight. To fix this, try taking the watch harness apart and putting it back together using this guide XXXXX. You can then clean around the buttons to make sure any debris is out of the way using a q-tip. If it needs to be re-oiled to provide a smoother motion you could do that as well.
Broken Sport Band
Rubber watch bands have a tendency to crack and break due to everyday use over long periods of time or after repeated exposure to things like saltwater which might cause them to dry out and rip faster. Either of these reasons could have been why this rubber sports band is broken.
The Band is Broken Into Pieces
Replacement of the wrist band would be the easiest option of repair. We are going to show how to take apart the old band and show how to replace it with the new one. To replace the band Use this guide. XXXXX
Band is Cracking
This could potentially lead to a complete break in the band, we recommend replacing the band once it has broken. We are going to show how to take apart the old band and show how to replace it with the new one. To replace the band Use this guide. XXXXX
No Display
The face on your Freestyle Cori Lopex III FS81322 doesn’t show anything, and you know the computer is turned on.
Faulty Battery
Issues with the backlight could be a malfunction in the battery. We suggest replacing the battery first and seeing if that fixes the unresponsive display. The battery is a basic CR2025 Lithium Battery. The Cori Lopex watch is equipped with a Maxwell brand battery, but any brand will suffice. To replace the battery Use this guide. XXXXX
Backlighting is Unresponsive
If the lighting still does not work after a battery change, then the issue may arise in the light bulb itself. In the case of a defective bulb, replacement would require a replacement of the entire motherboard. To replace the motherboard using this guide XXXXX
Freestyle Cori Lopex III Will Not Power On
Watch is not responsive.
Faulty Battery
The Display screen problems could be a problem with the battery, therefore, we will go in-depth on how to replace the battery for the watch. To replace the battery Use this guide. XXXXX
Spotting, Glitches, or Discoloration on Display
This could be a sign of water damage, Low charge of the battery, and damage of the motherboard
Water Damage
The first thing you can try would be to open up the watch by unscrewing the four screws on the back and pulling off the back of the watch. You then can unscrew the battery and motherboard to see if there are obvious signs of water damage to the motherboard of the watch. One cause of the water damage could be if the rubber seal around the back case panel is defective or has slid out of place. To replace rubber seal use this guide XXXXX. If there is water damage you can replace the motherboard. To replace the motherboard using this guide XXXXX
Faulty Battery
If the motherboard does not seem to have water damage, the next step would be to replace the battery. To replace the battery Use this guide. XXXXX
crwdns2944067:04crwdne2944067:0
Where is the guide to replace the battery? Thanks
cassiebvc - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Wher is the guide to replace the watch band
Leo Padilla - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Wher is the guide to replace the watch band on my lopex lll
Where is the guide to replace watch band lopexlll
