crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your watch battery drains quickly even after charging it fully, follow the troubleshooting tips below to resolve the issue.
High Brightness level
Consistently high brightness levels on both watches and phones can drain the battery faster due to the increased power required to maintain brightness.
  • Lower the screen brightness to an appropriate level.
  • Access the settings menu on your watch.
  • Navigate to "Display".
  • Adjust the brightness slider down.
The "Always On" Feature is Enabled
Go to your watch's Settings → Display → Toggle off Always-On Screen.
Excessive Notification Frequency
If you haven't adjusted the frequency of the notifications you receive from apps, customize the notification frequency to reduce notifications.
  • In the app, tap on your watch.
  • Select the gear icon.
  • Tap notifications.
  • Choose the notifications you want to customize and set your preferences.
The Watch Needs an Update
If your watch system is out of date, your battery may drain faster than usual. Note that you may have additional battery drain for a few days after a major update, but it should go back to normal after a few days. Check for updates in two places:
  • System update: On your watch, go to Settings → System → System updates
  • Watch app updates: On your watch, go to Play Store → Scroll down to the bottom of the page → Select Manage Apps → Select Update All if there are updates.
End of the Battery Life
All batteries have a certain amount of charging cycles so if your battery is older and has been charged more times than average, it will begin to degrade and you need to replace the watch battery. Follow the Fossil Q Venture Gen 3 Battery Replacement guide.
Christiana
crwdns2935283:009/09/24crwdne2935283:0
2 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
CSU Los Angeles, Team 2-1, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 2-1, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S2G1
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 507
