crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Antenna does not work
The antenna is not working
The antenna is loose
Movement and travel could cause the antenna to get loose or fall out. This can be fixed by ensuring the screw and washer sit tight on the antenna. The base of the antenna should be stagnate on the controller and fit tight to ensure it doesn't get loose again.
  • Step 1: Place the antenna on the port
  • Step 2: Make sure the nut in the box is tight
  • Step 3: Tighten the nut on the outside until the antenna is fit
For a more detailed guide, refer to:
The wire is disconnected from the motherboard
The antenna wire could have come out and disconnected from the motherboard. Carefully connect the socket on the motherboard to the connector on the wire. For instructions to fix it are here.
The antenna could not be properly connected to the controller
The antenna box should be connected in two places. It should be connected in the back and a second wire in the front. Make sure that both connections fit in their proper location.
  • Step 1: On the controller, there are five tongs. Carefully align the box with the tongs; it should fit flush.
  • Step 2: A wire comes out of the controller, and a rectangle on the top left of the box. Carefully plug the wire into the box and ensure it won't fall out.
Button input lag or no response
Buttons are stuck, broken, or the buttons are missing
Buttons are sticking when being pressed
Make sure the area around the buttons is debris-free before attempting to push the buttons. For a simple fix,
  • Step 1: Take a brush and clean the gaps and edges of the button, be sure to get as deep in the gaps as possible.
If the problem persists, refer to:
No response when pressing a button
Buttons can break internally or externally, as a result they will not provide a response. To fix this you must replace the entire button motherboard. Link to the replacement part here. Button Motherboard
Springs Are Broken Or Missing
Switches aren't working
Your switch isn’t doing the intended input for any reason
The switch is clogged with debris
This is possibly due to dust and debris accumulating inside the gaps of the switch. If this is the case, the fix is quite simple.
  • Step 1: Grab a needle or something small enough to get into the gaps and break up the dirt and debris.
  • Step 2: After that, it is recommended to use some compressed air to clean the gaps thoroughly.
For a more detailed guide, Refer to:
Wires are not connected properly to the switch
Over time, the wires connected to the switch may have been disconnected or broken. This is possible to diagnose and fix by opening the controller and assessing the damage. To do this, refer to the guide linked:
The switch is broken and needs to be replaced
Repeated switch use will cause the switch’s internal components to break down. This can only be fixed by replacing the entire switch.
The controller features do not turn on
The controller and or features do not turn on
The batteries are dead
The most common reason the controller is not turning on is because the batteries are dead and need replacing. If you would like to do this, please follow the steps below.
  • Step 1: Locate the battery compartment on the back, Grab both ends, and pull down until the compartment opens up.
  • Step 2: Locate the battery pack containing all of the batteries, and pull it out (Make sure to be gentle as not to break the wire connected)
  • Step 3: Replace all of the batteries with fresh, working batteries
The display screen is displaying a switch error
When the controller displays an error message that says "switch error", you will need to follow a few steps to turn that message off
  • Step 1: Turn the controller off
  • Step 2: Switch the front panel switches in the upright position
  • Step 3: Switch the top panel switches towards the back of the remote
  • Step 4: turn remote back on
The battery harness is broken
Repeated impact and rough treatment can cause the harness to crack or break. If this is the case, you must replace the harness entirely. For a more detailed guide, Refer to:
Joysticks aren't working
The joystick does not work and moves on its own
Loose Joysticks
Joystick is not functional because it can become loose over time.
Often with controls, the joystick that controls most movement can become loose or too tight. This is adjustable by design, to do so refer to:
Stick Drift
Over continued use, the joystick tends to move on it's own without you moving the joystick. This is fixable by replacing the entire joystick. For a more detailed guide, Refer to:
Loose Spring in Joystick
The main joysticks have springs that help maintain stability and hold them in place. Whenever the switch does not move or is moving on the springs, it could be out of place or worn out. For a detailed guide refer to:
Heath Soucheck
crwdns2935283:002/09/23crwdne2935283:0
715 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-3, Saru Jimmy Spring 2023 crwdns2935289:0University of North Texas, Team 3-3, Saru Jimmy Spring 2023crwdne2935289:0
UNT-SARU JIMMY-S23S3G3
crwdns2959996:0crwdne2959996:0 1,119
