crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Flip MinoHD won't turn on
No matter what you do, you can't get your Flip MinoHD to turn on.
Device needs reset
Before delving into the guts of your Flip MinoHD, make sure it doesn't just need to be reset. To reset the device, hold the reset button for 10 seconds by placing a pin into the reset hole on the device until the display turns off and back on.
Drained battery
If your Flip MinoHD won't turn on, you may simply have a drained battery and it must be charged by plugging the device into an outlet using the charger.
Bad display
It is possible that it appears nothing is happening because the display is bad. If your device is charged and reset it is possible the display is bad and must be replaced. Check out our display guide to do so: Flip MinoHD Display Screen Replacement
Bad battery
If the Flip MinoHD is charged and will still not turn on, it is possible the battery needs to be replaced. You can follow step by step how to replace the battery here with our battery guide: Flip MinoHD Battery Replacement
Bad logic board
If the Flip MinoHD still will not power on, the problem most likely lies in the logic board and should be replaced. You can follow how to replace the logic board here with our logic board guide: Flip MinoHD Motherboard Replacement
Flip MinoHD not recording
Flip MinoHD stops recording or only records for a limited amount of time.
Device needs reset
Drained battery
Storage full
It is possible that the Flip MinoHD's storage is full and files must be transferred to a computer through USB connection. Connect the device via USB port to a computer and export all remaining files on the device to the computer. Deleted files must be moved to the trash bin AND emptied. If this folder is not emptied, recording space may still be limited. Reset your device after the files have been transferred and your device's recording capacity should be restored.
Buttons not responding
There is no response or affect of pressing the buttons.
Device is frozen
Battery is overheated
Remove the batteries or rechargeable battery pack. You may wish to blow on the battery or its insert to ensure it is cooled down or cleaned out. Reinsert the battery and press the power button to turn on.
Flip MinoHD will not charge
No matter what you do, you can't get your Flip Mino HD charge.
Disconnect the battery by following our guide, and let sit for about 2-3 minutes to cool. Reconnect and make sure the device is reassembled, then power back on.
Drained/bad battery
Replace the battery by following our guide here: Flip MinoHD Battery Replacement
Dust/ in charging port
Clean the charging port by powering off the device and lightly blowing into the port/cleaning with a dry tissue to remove any dust. After cleaning the port you can power up the device.
Device will not connect to TV
The play button has no effect when you connect your device to the TV in order to watch your videos.
Faulty adapter
It is possible that there is not a problem with the device and the adapter is broken and needs to be replaced in order to establish a connection between device and television.
Dust in port
Abigail Buckenberger
crwdns2935283:001/06/16crwdne2935283:0
732 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-1, Andersen Winter 2016 crwdns2935289:0Eastern Washington University, Team 2-1, Andersen Winter 2016crwdne2935289:0
EWU-ANDERSEN-W16S2G1
crwdns2944067:05crwdne2944067:0
If I reset my flip mino hd will I loose all of the videos made that are still in the device?
Pilot S - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i like to buy this mino hd main motherboard , where can i buy it from?
Teo Chwee Soon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Flip mino Hd wont turn on after years of not using, but when I charge its red?
weo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
you can use a paper clip to reset it and then plug it in, or you have to replace the battery
Aidyn P - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
the camera is taking gliched videos. what would that fall into?
person - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 103
crwdns2959996:0crwdne2959996:0 21,317
