This page covers the most common issues with the FixHub Portable Soldering Station, the FixHub Smart Soldering Iron, and the web console used to update them. Most issues are resolved by updating firmware to the latest release — start by opening the https://www.ifixit.com/fixhub/console.
To update firmware, plug your station (or iron) into a computer with a USB-C data cable, open the web console in Chrome, Edge, Opera, or Brave, and follow the prompts. The iron and station update separately — see the firmware-update section below if you run into trouble.
If none of the steps below resolve your issue, contact iFixit support.
Power station won't turn on, won't charge, or arrived dead
A new or stored station that won't power on or refuses to charge is almost always a firmware-related boot issue rather than a hardware failure. The most common cause was a low-battery boot bug fixed in firmware 1.4.0.
On firmware 1.4.0 or later, plug the station into a standards-compliant USB-PD wall charger (15W or higher recommended). It should begin charging within a few minutes even from a fully discharged state.
On older firmware, a deeply discharged station can't accept power from a USB-PD wall charger because the firmware browns out before USB-PD negotiation completes. The workaround:
  • Plug the station into a computer using a USB-A to USB-C cable (not USB-C to USB-C). USB-A delivers a small trickle of power without requiring firmware to be running, which keeps the unit awake long enough to boot.
  • Wait 15–30 minutes for the battery to gain enough charge to hold a boot.
  • Open the web console and update to the latest firmware. Once on 1.4.0 or later, normal wall chargers will work.
If the station still won't wake on either path, gently reseat the battery connector behind the back cover (see the relevant repair guide on iFixit).
If none of the above works, contact iFixit support for a replacement.
Iron won't heat, shows "Actuator Fault," or shows "Tool Error"
Iron heating problems fall into two groups, and the right fix depends on which signals you see.
If the iron makes cracking sounds, buzzes on plug-in, or the temperature rises and then drops
These are signs of a failed heater or temperature sensor inside the soldering tip itself. Other indicators include:
  • The iron won't heat past a specific low temperature (e.g. "stuck at 59°C")
  • The LED ring flashes blue rapidly while attempting to heat
  • The LED ring shows a solid orange ring at startup
  • "T05" or "T06" sensor errors on the screen
The fix is to replace the soldering tip — these are sure-fire tip failures and a fresh tip will resolve almost all of them. If the same symptoms persist with a brand-new tip, the iron handle itself is faulty; contact iFixit support for a replacement iron.
If the iron shows "Actuator Fault" or "Tool Error" without cracking, buzzing, or temperature instability
This points to an intermittent contact problem at the tip-to-iron connection rather than a failed tip. The error often clears if you twist or press the tip from a specific angle.
  1. Update firmware first. Older firmware sometimes mislabels routine tip-disconnect events as "Actuator Fault." Updating to the latest firmware resolves a portion of these reports.
  2. Reseat the tip firmly. Pull the tip out, wipe both contact surfaces with a clean cloth, and reinsert it. Try rotating it slightly in the socket and pressing at different angles. If the error clears predictably with rotation or pressure, that confirms an intermittent contact issue.
  3. If the error persists on current firmware after a clean reseat, the iron's tip receiver is the issue and a tip replacement won't help. Contact iFixit support for an iron replacement.
If the tip glows red-hot at a low setpoint (safety)
If a brand-new tip rapidly overheats — for example, glowing red at a 250 °C setpoint, or melting the protective cap — stop using the iron immediately. This is most often a defective tip whose temperature sensor is mis-reading, but it's safety-adjacent. Contact iFixit support for both a replacement tip and a replacement iron, and keep the failed tip aside for analysis.
Battery error codes (B01, B02, B03, B04) on the OLED
The B01 through B04 codes refer to anomalies in the station's battery management system. Almost all reports have turned out to be firmware misinterpreting normal battery state — the cell itself is fine.
  1. Update the station to firmware 1.5.0 or later. Each B-code was fixed in a different release; updating to the most recent firmware addresses all four.
  2. After updating, power-cycle the station to clear any cached error state.
If a B-code still appears after updating to the latest firmware, contact iFixit support for diagnosis.
Firmware update fails or web console can't find your station or iron
The web console uses WebSerial, which is only available in Chromium-based browsers and only over a true USB data connection.
Browser: use Chrome, Edge, Opera, or Brave. Firefox and Safari don't implement WebSerial. Heavily-locked-down corporate or school Edge installations sometimes have WebSerial disabled — try the web console on a personal computer if your work machine doesn't connect.
Cable: many USB-C cables are charge-only. If the web console can't see your station, try a different cable — ideally a USB-A to USB-C cable, which has reliable data lines.
Laptop: Dell Precision and Dell XPS laptops sometimes refuse to negotiate data over their USB-C ports because the port is reserved for a docking-station protocol. If your machine is one of these, plug into a USB-A port instead.
To update the iron, plug the iron directly into the computer with a USB-C cable. Do not update the iron while it's connected to the Power Station — the web console can only talk to one device at a time, and it will only see the station, not the iron behind it.
On Linux, if the web console reports "Another connection open," your user account doesn't have permission to claim the serial device. Add yourself to the <code>dialout</code> group:
<pre>
sudo usermod -a -G dialout $USER
</pre>
Then log out and back in (or reboot) and try again.
Iron disconnects intermittently or "Firmware mismatch" keeps appearing
Most intermittent iron-detection problems are noise on the tool-detection circuit and were fixed in firmware 1.1.2. Update both the station and the iron to current firmware first.
The "Firmware mismatch" message that briefly appears when you plug the iron in and then disappears after a few seconds is harmless — it's a display artifact while the version handshake completes. To eliminate it permanently, update the iron firmware directly (plug the iron into the computer, not through the station) so the iron itself receives the corrected version code.
If the iron still disconnects randomly on current firmware after a clean reseat at both ends, contact iFixit support — that points to a hardware fault, usually on the station side.
Station charges slowly or won't charge from a specific charger
The FixHub Power Station accepts USB-PD up to 45W. Two things can cause slow or no charging:
Non-standard PD chargers. Some laptop-branded bricks (Dell, OnePlus, certain Samsung laptop chargers) advertise proprietary profiles that only their host laptops recognize. The station can't negotiate with these and will either trickle at low wattage or refuse to charge entirely. Use a standards-compliant USB-PD charger.
The station accepts up to 45W — it doesn't require 45W. A 30W or even 20W charger will work, just more slowly. You don't need a specific high-wattage brick.
Samsung phones charging at ~2W from the station's front ports. This is fixed in firmware 1.5.0, which adds support for the PPS charging standard that Samsung S23 and S24 series phones request. Update the station to 1.5.0 or later and Samsung phones will charge at full speed.
Display is dark but the station otherwise responds
If the OLED is dark but the web console can still connect to the station over USB-C — meaning the station is otherwise booting and working — the display itself or its internal connector is the problem.
If you're comfortable opening the unit, gently reseat the display's internal flex cable (see the disassembly guide on iFixit). If reseating doesn't restore the display, or you'd prefer not to open the unit, contact iFixit support for a replacement.
The small LEDs visible inside the station near the main board are status indicators that briefly flash during boot and then turn off. A solid-on LED can mean the unit is in firmware-update mode or has a firmware fault — but the LEDs are not error codes, and you don't need to read them to diagnose anything.
Phone won't connect to the iron over USB-C
USB-C host-mode behavior varies a lot across Android phones and some laptops. The FixHub iron is standards-compliant on its end, but some Fairphones, Xiaomis, certain Pixels, and a handful of HP and Lenovo laptops won't enumerate the iron over their USB-C ports.
If the iron app can't see the iron from your phone:
  • Try a USB-A hub adapter between the phone and the iron.
  • If that still doesn't work, use a desktop or laptop computer with the web console instead. The web console works reliably on any Chromium browser.
Tip is stuck in the iron
If the soldering tip won't pull out, it's usually because flux residue and heat-cycling have fused the tip's outer sleeve to the receiver. The tip is not damaged.
  1. Clean the tip-to-iron joint with isopropyl alcohol (IPA). Apply generously around the seam and let it soak for a minute or two.
  2. Try pulling the tip out by hand again. If it's still stuck, use pliers with a microfiber cloth wrapped around the tip to avoid scratching the stainless steel, and pull with steady force.
  3. If the tip is genuinely seized after IPA and gentle pliers, contact iFixit support — that's a rare physical-galling case that may need replacement.
Less-common issues
  • Battery health reads 85–92% on a new or lightly-used station. Not a defect — Battery Health is a calculated metric that's noisy until the pack has seen at least one full charge/discharge cycle. The reading self-corrects with normal use.
  • "Station Error Update Firmware" or "S17" error. This means one of the station's two MCUs didn't finish its update. Retry the firmware update once and let it run all the way through without disconnecting. Do not downgrade the firmware. If the retry fails, contact iFixit support — there is currently no host-side recovery path for this state.
  • Power button intermittently doesn't respond. After a long press, the button's hold-capacitor takes about 20 seconds to discharge before it'll register another press — that's normal. If presses fail at random rather than only after a long press, contact iFixit support.
  • Station won't fully power off ("shutting down" appears, then the battery percentage returns and a Battery Error follows). This is a known hardware defect; contact iFixit support for a replacement.
  • Iron LED ring is completely off and the iron isn't recognized on any charger or computer. This indicates a hardware fault on the iron's USB-C input side. Contact iFixit support for a replacement iron.
  • Continuous "Freefall" errors during normal stationary use. The iron's onboard accelerometer has failed. Contact iFixit support for a replacement iron.
If none of the above resolves your issue
Contact iFixit support with:
  • The serial number of the station and/or iron
  • The firmware version of each (visible in the web console)
  • A short description of the symptom, including any error code or LED pattern
  • A photo or short video of the issue if it's visual
For complex or multi-issue cases, our support team will route you to the right specialist directly.
Brett Hartt
crwdns2935283:004/12/10crwdne2935283:0
132,418 crwdns2915208:0crwdne2915208:0
crwdns2935297:0144crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:086,246crwdne2935297:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 326
