crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your Euhomy IM-06D ice maker not making ice? There can be many reasons for this and through this guide we will help pinpoint the issue for you to fix it.
Device Not Powered On
Make sure the device is plugged into an outlet. Ensure the outlet has power using either another appliance you know works or a tester if you have one. Make sure the power cord is not damaged in any way. Try hitting the on button again after checking all of these. If this still does not power on you may have a power supply issue and need to replace it to fix the issue. See power supply guide for further help.
Water Tank is Empty
Confirm there is water in the machine's tank and that it is fully filled up.
Make sure the machine is not leaking water from the tank.
Water line not properly attached
Reattach the water line and refill the tank.
Water line damaged
See water line replacement guide for further help.
Water line clogged
Check to see if it is clogged and water cannot flow through
If it is clogged, try to flush the lines to clean them. If this does not work, you need to replace them. See water line replacement guide for further help.
Compressor Issue
If the previous steps did not work the compressor most likely needs to be replaced. See compressor replacement guide for further help.
Joel Mello
crwdns2935283:003/21/25crwdne2935283:0
418 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 2-5, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S2G5
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 518
