crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your Euhomy IM-06D ice machine not powering on? If the ice machine isn't powering on properly, you won't be able to obtain the proper ice you desire, in this trouble shooting page we will go over the steps you should follow in order to identify this problem.
Ice Machine isn't plugged in
Ensure that the power cord isn't knotted in anyway, and that it is plugged fully into an outlet
  1. Once you have ensured that this isn't the problem try plugging another item into that outlet to ensure that the outlet is working properly
Ice Machine's cord is damaged
Now that you know it plugged in, and the outlet works start by holding the power on button to ensure that the ice machine has the ability to reset and try to power on.
  1. If it still doesn't power on check if your cord is frayed or damaged in anyway
  2. If there is damage to the cord, see cord replacement guide attached below.
Ice Machines power supply is damaged
Now that you have ensured that the outlet works, and the cord isn't damaged it's safe to say your power supply is damaged.
  1. For the steps on how to replace the power supply please see attached link to the power supply replacement guide.
devin wordell
crwdns2935283:003/21/25crwdne2935283:0
192 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 2-5, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S2G5
crwdns2942667:0crwdne2942667:0 284
