crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Won't Power On
The Radar will not respond or show any sign of powering up.
Faulty Lighter Adapter
Ensure the lighter adapter is plugged in and the on light is on. If the light is not on, and the adapter is plugged in, the adapter is faulty. Consider purchasing a replacement adapter.
Distorted Audio/No Sound Is Produced
The sound being produced by the radar sounds staticky or no sound is being produced at all.
Faulty Speaker
If the sound from the radar sounds distorted or won’t produce sound when it should be, then the devices speaker could be at fault. Go to Escort Radar 9500IX Speaker Replacement Guide and follow the steps to replacing your radar speaker.
Display Hangs On Black Screen
Your radar’s display is black and won’t show anything on its display.
Make sure that the radar is connected and powered on. If the radar is connected but doesn’t power on, then you could have a faulty lighter adapter and needs to be replaced.
Faulty Display
If the radar’s display isn’t responding and just stays on the black screen, then the display is damaged and at fault. First check to see if the display brightness is up. If the brightness is up and the display is still on a black screen, then the display is at fault. Contact Escort Radar Company to replace your radar.
Device Does Not Respond
The device doesn't respond when pressing down on any of the buttons.
The Version Is Too Old
Your device might be an older version and out of date and might not be able to connect to your vehicle. Try downloading the most recent version. Go to How to Update Escort Passport 9500IX to update your radar.
Kennedy Morales
crwdns2935283:010/20/17crwdne2935283:0
664 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G3, Peak Fall 2018 crwdns2935289:0UMass Dartmouth, Team S2-G3, Peak Fall 2018crwdne2935289:0
UMASSD-PEAK-F18S2G3
crwdns2935297:084crwdne2935297:0
crwdns2944067:06crwdne2944067:0
My device just took a crap power cord has a light but the device no light and sound
I V - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Passport 9500i is:
1) No longer marking locations
2) I had to replace the speaker last year. It started blasting unnervingly LOUD in certain interference locations. Not all though.
Any suggestions or solutions would be greatly appreciated.
Tom
raindog264 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I use my Escort in Europe as well. The Ku-band however, cannot be set. When I check the Ku-band and hit the Change to be saved to the detector it unchecks it. What is the problem here?
Paul - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Any insight would be greatly appreciated.. My device powers on and stays on as well as I can change the functions. The problem is as soon as it senses and goes to alert it immediately tells me to reboot power and stays on that message. I am going nuts because I only have had this device for 3 months and has done this since I received it. Thank you beforehand.
John Doe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
To John Doe:
In my opinion, you need to return it for exchange. That is a faulty unit.
It is too bad that this site is not monitored by the Escort folks and no one reply.
Paul
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 8,348
