crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Scale Will Not Turn On
The scale will not respond to "on" button being pressed.
Faulty or Low Battery
Replace batteries if they appear damaged or old. Ensure batteries are properly inserted into the device.
Display Does Not Turn On
The display will not read anything.
If your display appears blank you may need to replace the batteries or make sure that they were properly inserted into the device. When the batteries have a low charge, a low battery symbol will appear on the display.
Display Reads Inaccurate Measurements
Display does not read the accurate weight of objects.
Unstable Measuring Surface
Place the Escali P115M on a flat surface free of vibration. Make sure you keep your scale at room temperature to ensure its accuracy.
Display Reads "EEEE" Error Message
Display reads "EEEE" when objects are placed on it.
Scale Is Over Capacity
The Escali P115M has a measuring capacity of 5000 gram / 11 pound / 175 ounce. If the object you are measuring is over this weight, the scale will read, "EEEE." Remove weight and place a lighter object on the scale to ensure scale is working properly.
Display Reads "OUT2" Error Message
Display reads "OUT2" when objects are placed on it.
Incorrect Calibration
To recalibrate the Escali P115M, you are required to have a 5kg or 11lb weight. You can download recalibration procedures here.
Kristen Hagler
crwdns2935283:001/30/17crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
University of North Texas, Team 1-5, Campbell Spring 2017 crwdns2935289:0University of North Texas, Team 1-5, Campbell Spring 2017crwdne2935289:0
UNT-CAMPBELL-S17S1G5
Difficult to turn on and to change oz-gram. Press multiple times. New Duracell batteries. Does it need to be cleaned and how.
Linda Lambert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 94
crwdns2959996:0crwdne2959996:0 4,783
