crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Audio Distortion
The speaker does not sound clear when turned on.
Loose Wire
When the sound cuts in and out or when the the volume is inconsistent, a loose wire/ground may be the issue. The loose connection will result in the variance of the speaker's ability to produce sound and will need to be tightened or replaced.
Defective Speaker Cone
If sound from the speaker is still inconsistent, the speaker cone may be bent or punctured. If this is the case, the cone will have to be replaced.
No Audio
You try to turn the speaker on but cannot play music through it.
Loose Wire
If the the speaker is not functioning, there may be loose wiring within the housing. If so, the wire connections may need to be repaired or the wires themselves may need to be replaced.
Faulty Voice Coil
If the sound continues to be nonexistent, the voice coil may be defective. The voice coil is located within the speaker assembly and will need to be replaced.
Battery Will Not Hold A Charge
The speaker is constantly dead, even if you charge it.
Battery Jack
Press the power button to see if the power indicator light turns on. If it does not turn on, plug the charger to the jack. If nothing happens, the jack may be faulty and will have to be replaced.
Battery
If the jack is working fine and all connections are tight, the battery within the unit could be dead and will have to be replaced.
Controls Not Responding
Speaker appears to be on, but the buttons are not responding.
Loose Wire
If the speaker does not respond when the controls are depressed, there may be a loose connection to the button.
Buttons
If the speaker does not respond when controls are depressed, they will have to be replaced due to a faulty switch within the button.
Display Lights Not Responding
Speaker appears to be on, but the indicator lights are not responding.
Loose Wire
If the bluetooth and power indicator lights do not turn on when the speaker is on, there may be a loose connection to the LED light.
Bad LED
If the display lights are not functioning, the LED light will have to be replaced.
James Lipsett
crwdns2935283:003/20/17crwdne2935283:0
625 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S9-G3, Martin Spring 2017 crwdns2935289:0UMass Dartmouth, Team S9-G3, Martin Spring 2017crwdne2935289:0
UMASSD-MARTIN-S17S9G3
crwdns2944067:070crwdne2944067:0
Bluetooth works fine. Radio tunes in sound very distorted. Like if the antenna was not connected.
Miguel M - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes I’m having a similar issue-radio doesn’t work at all. I’ve tried moving the whole speaker to spots in the house with higher bandwidth, disconnecting bluetooth, tried every station. Any help on this?
charlotte - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Speakers are fine with Bluetooth. Just the radio doesn’t work sound is very distorted. Like the antenna is not connected. Or something else.
Speaker won’t turn on unless connected to power! Help! What should I do?
Kiany Porte - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same issue, did u get an answer?
Abe Lovely - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 243
crwdns2942667:0crwdne2942667:0 41,853
