crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Dyson DC58 shuts off while in use
The vacuum is working normally then suddenly shuts off!
Low battery level
It sounds simple but a dead battery is the most common cause of the vacuum powering down while in use. Charge the vacuum battery for a minimum of 2 hours. After the battery is fully charged, power on the device.
Blockage of nozzle/attachments
When a part becomes blocked or clogged the vacuum will automatically shut off to prevent any further damage. To clear blockages, first turn the power off and unplug the vacuum. Next, remove the tool head from the wand. Then, remove the wand from the vacuum base. Visually inspect the inlet of the vacuum base, the inside of the wand, and the neck/base of the tool head. Remove any visible blockages. Once blockages are removed, power on vacuum and continue with normal use.
Clogged filter
If the filter becomes blocked the vacuum will not function properly. To remove the filter twist the purple dial labeled "filter" located at the top of the vacuum. Next, simply pull the filter out of the vacuum and rinse it under running water for a minimum of 2 minutes. Rinse and gently shake the filter to remove any built up debris. After rinsing, gently wring out the filter to remove excess water. Next, place the filter in a warm dry environment to allow it to dry for 24 hours. After a minimum of 24 hours, place the filter back into the vacuum and continue with normal use.
Dyson DC58 doesn’t power on, even after charging
My vacuum won’t turn on no matter what I try!
Non-functioning battery
When your Dyson no longer powers on even after charging the most likely cause is a damaged battery. This means the battery will no longer hold a charge and will need to be replaced. Once a new battery is purchased you can learn how to replace it by visiting our battery replacement page here.
Dyson DC58 keeps losing suction
My vacuum was working fine, but now it's losing suction!
Clogged Brush Bar
One of the most common causes of reduced suction power is a clogged brush. Locate the two dials on the brush head attachment of the vacuum. Turn each one a quarter-turn, counter-clockwise until it clicks. Turn the cleaner head over so you can see the sole-plate. Finally, remove the sole-plate and clear any hair or debris from around the brush bar. Replace the sole-plate and turn the dials on the brush head clockwise. Power the device on and continue with normal use.
Dyson DC58 omits unusual smell when on
There is an unusual smell when I use my vacuum!
Clogged Filter
An unusual smell is a common problem associated with the Dyson DC58. It turns out that after some time the filter begins to clog and all the built up debris begins to omit a burnt smelling odor. See "Clogged filter" above to learn how to clean the filter. If the filter is too dirty to clean it will need to be replaced. Learn how to replace the filter here.
Dyson DC58 makes an unusual sound
My vacuum makes strange sounds while I’m using it!
Air Leak
If the vacuum is producing whistling noises, it may be the result of air leaking out of the vents. Make sure to check for broken seals and incorrectly fitted parts. Broken seals may require replacement.
Motor Failure
If your vacuum makes a popping noise along with pungent burning smell a failing motor may be the cause. This will involve replacing the main body of the vacuum which contains the motor. Learn how to replace the main body here
Clogged Filter
A clogged filter can create a muffled sucking sound or a high pitch squeal during vacuum use. To fix this problem see "Clogged Filter" above.
Herllaine Asistio
crwdns2935283:009/17/15crwdne2935283:0
239 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-4, Bruce Fall 2015 crwdns2935289:0CSU Fullerton, Team 2-4, Bruce Fall 2015crwdne2935289:0
CSUF-BRUCE-F15S2G4
crwdns2944067:0103crwdne2944067:0
The lights come on and the motor doesn't turn. I thought it was just a contact issue. The max button lights along with the small power light. But still nothing.
Christopher patrick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mine does EXACTLY the same thing. Was running perfectly, then just stopped! I will check for blockages and dirty filter. It seems Dyson doe not have an answer that I can find for this problem.
deepdudu - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
mine does same thing blue light come on when I pull the trigger but moter doesn't come on and when I try to charge not light comes on indicate that the vac is charging
William Johnson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hey! did you ever find out a solution to this problem you listed? Same friggin’ thing with my handheld and it’s so frusterating! :(
Chloe Mills - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I found the solution to it ‘shutting off’ after a few seconds is to WASH the tiny blue filter at the top. Pull it out and rinse under Warm water using dish soap to scrub the filter….you should see black dirt rinse out. After it dries thoroughly (about a day) reinstall and it will work as normal. I keep an extra filter on hand so I can swap one in while I wash/dry the other.
Good luck!
Geo Peo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 115
crwdns2959996:0crwdne2959996:0 378,660
