crwdns2862674:0crwdne2862674:0
This wiki page is a stub. Help us improve this page by adding information to it!
Cell vs. Pack
  • Battery packs used in drones consist of multiple lithium-polymer (LiPo) cells.
Capacity
  • Each cell has a capacity measured in milliamp hours (mAh).
  • All cells in a pack have the same capacity.
Cell Voltage
  • Full Charge: 4.2 volts per cell
  • Nominal: 3.7 volts per cell
  • Discharged: 3.5 volts per cell
    • Discharging a LiPo battery past this level will result in permanent damage.
Charge and Discharge Ratings
The C rating found in the name of the pack (see below) refers to the maximum discharge rating. Multiply this number by the pack capacity for max current draw.
  • Max current draw for a 5000mAh 40C pack: 200Amps (5000mAh * 40C)
Battery Notation
  • Example Battery: Turnigy 5000mAh 4S 40C Lipo Pack
    • Brand: Turnigy
    • Capacity per cell: 5000mAh
    • Number of cells: 4
    • Nominal Voltage: 14.8v (3.7v * 4 cells)
    • Maximum Discharge Rating: 40C
    • Maximum Charge Rating: 5C (Found on Product Page)
David Hoyt
crwdns2935283:004/09/10crwdne2935283:0
4,053 crwdns2915208:0crwdne2915208:0
crwdns2935297:039crwdne2935297:0
Cal Poly, Team 25-89, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-89, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G89
crwdns2935297:0563crwdne2935297:0
Battery is available at the DJI service support www.mataelectronics.in
rahul upadhya - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 3,154
