Device Won't Turn On
The device will not start.
Battery Isn't Charged Enough
If the computer's battery isn't charged enough, the computer won't turn on. Try charging your device by plugging the power supply into the computer's power jack, located at the bottom center of the device. Make sure the power supply is securely plugged into both the device and the outlet.
Battery Is Damaged
If you've left the computer charging for an extended length of time, but it still won't turn on, either the device's power jack or the device's battery may be faulty. In either case, a replacement may be required; in the case of the battery, you may follow this battery replacement guide.
Device Keeps Restarting
The device turns on, but there is some issue preventing initial, or continued use.
Battery Is Damaged
Sometimes the computer will turn on while the charger is plugged in, but shut off when unplugged, regardless of how long it's been left to charge. If this is happening to your device, its battery may be damaged and require replacement. You can use this guide to replace it.
Sound Is Faulty
The device's speakers have distorted or no sound.
Speakers Are Damaged
When sound from a computer's speakers is distorted in some manner such as: popping, muffled, scratchy, or non-existent, when playing music or watching videos, one or both of the device's speakers may be faulty. If you hear any of these distortions, you may need to replace your device's speakers; you can use this speaker replacement guide to help you.
Device Won't Connect To Wifi
The device won't connect to wireless internet.
Computer Needs To Restart
If your computer turns on and starts up as usual, but won't connect to any Wifi signals when you want to connect to the internet, something may not have loaded properly while the device was starting. Locate your device's power button on the upper-right side of the screen, press and hold the button until the device's screen goes black. After about one minute, press the power button once more to restart your device.
Wireless WLAN Card Is Damaged
If your computer turns on and starts up as usual, but won't connect to any Wifi signals when you want to connect to the internet, and you've restarted the device multiple times, your device's wireless WLAN card may be faulty. The wireless WLAN card allows the device to connect to Wifi signals, and if it's faulty, the device may be unable to connect to the internet wirelessly. In this case, you may need to replace your device's wireless WLAN card; you can use this wireless WLAN replacement guide to help you.
Touchscreen Isn't Working
The device turns on, but doesn't respond when touched
If your computer turns on and starts up as usual, but doesn't respond when you touch the screen, something may not have loaded properly while the device was starting. Locate your device's power button on the upper-right side of the screen, press and hold the button until the device's screen goes black. After about one minute, Press the power button once more to restart your device.
Touch Control Board Is Damaged
If your computer turns on and starts up as usual, but doesn't respond when you touch the screen, and you've restarted the device a few times, your device's touchscreen may be faulty. In this case, you may need to replace your device's touch control board; you can use this touch control board replacement guide to help you.
Device Cannot Stand Alone
One or both of the device's support feet are faulty.
Support Feet Are Damaged
If the support feet that fold out from the bottom of the device are damaged, they may need replacement. Since they are partially secured with magnets, it may be possible to delay replacement by using the support feet with caution.
Austin Weir
crwdns2935283:001/31/15crwdne2935283:0
1,308 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-29, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 6-29, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S6G29
crwdns2935297:096crwdne2935297:0
My device (Dell XPS 18) doesn't properly turn on and when pushing power button and only power button indication light blinking regularly as following:
7times blinking and delay and again 7 times blinking
anrew waleta - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My screen light up but nothing come on it the Dell sign doesn't show nothing blank screen
IRVIN DORRIS - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 3,569
