crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Dell Venue Pro does not show a charging icon and the battery level does not increase when connected to a charger, follow this page for possible solutions.
Faulty Charging Cable or Adapter
  • Inspect the cable and adapter for visible damage.
  • Test them on another compatible device.
  • If they fail, replace them with Dell-approved accessories.
Dirty or Damaged Charging Port
  • Look for dust, lint, or corrosion inside the port.
  • Clean gently using compressed air or a soft brush.
  • If the problem persists, replace the charging port.
Battery Age or Cell Degradation
  • If your Venue Pro only works when plugged in, the battery may no longer hold a charge.
  • Replace the battery.
Software or Power Controller Glitch
  • Disconnect the charger and hold the power button for 10–15 seconds to reset.
  • Reconnect and look for a charging symbol.
  • If the issue remains, perform a factory reset or firmware reinstall.
Motherboard or Charging IC Failure
  • Connect the device to a computer using a USB cable.
  • If it is not detected, the charging circuit or mainboard may have failed.
    Professional repair is recommended.
Todjay A Orr
crwdns2935283:010/29/25crwdne2935283:0
719 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team 3-7, Dieterle Fall 2025 crwdns2935289:0Purdue University Northwest, Team 3-7, Dieterle Fall 2025crwdne2935289:0
PNW-DIETERLE-F25S3G7
crwdns2942667:0crwdne2942667:0 111
