crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Computer Screen Frozen Blue
The computer will not respond to any commands.
System Reboot
Try turning the system off and back on giving it some time to stay shut down in between. This is good if the problem came out o nowhere. If the screen is still blue and unresponsive then move onto the next step….
Reinstall Software and Drivers
Update software to the latest version of windows. Type “check for updates” into the search bar in the bottom left corner of the screen, If there are any updates available, windows will inform you and prompt you to update.
Customer Support
The problem may be more in depth than originally thought and at this point, you should contact Dell with other options as to what to do going forward.
https://neosmart.net/wiki/blue-screen-de...
Battery loses charge quickly
The computer does not hold a charge for very long.
Software Updates
Update software to the latest version of windows. Type “check for updates” into the search bar in the bottom left corner of the screen. If there are any updates available, windows will inform you and prompt you to update.
AC Adapter
Make sure your charging cable is properly plugged in and isn’t cut or frayed. A cut in the cable could prevent it from getting a charge to the laptop. if possible, try a different cable to see if that’s where the problem lies. If this does not work, restart your PC. Once you see the Dell logo, press F2 until the setup page appears.
Battery
If the computer is old, it may be time to replace the original battery. On this laptop, it is very straight forward. To do this, push the button on the bottom of the laptop and it will pop out. If this does not work, one could turn off the Dell, and charge the battery while it is off. After, the PC has charged, restart the computer, and press F2 for system set up.
https://www.dell.com/support/article/en-...
Keyboard not responding
Computer’s keys appear to be broken or will not respond.
Clean Keyboard
If the keys are not working, clean the keyboard. Wipe down the keyboard with a microfiber cloth or use canned air to remove dust from under or around the keys,
Restart PC/ Check individual keys
If cleaning the keyboard does not work, try restarting your PC and see if the keyboard is working. A after restarting, check to see if the problem is the whole keyboard or specific/individual keys.
Reinstall Driver
If a restart of the PC does not work, try uninstalling the keyboard driver form the control panel section labeled “keyboard.” The keyboard software may be out of date and require new software.
https://helpdeskgeek.com/help-desk/how-t...
HDMI and USB ports not recognizing devices
Computer will not respond to outside devices being plugged in via HDMI or USB port.
USB Cable
Check to see if the cable you are using has any cuts in the wire that may be preventing a good connection. Plug in to another device in order to check functionality. Also try another port on the laptop to figure the source of the problem.
USB Port
if the cord seems to be in working order, it may be a bad USB port on the laptop. Try another port and see if the problem resolves itself.
System Update
Try checking the system settings to see if there is an update available tat might affect the response of the ports. If there is no such update, contact Dell for support regarding failed ports.
https://www.lifewire.com/fix-usb-ports-4...
Restart your computer. When it is done restarting, plug the cable back into the HDMI or USB port and check if the laptop recognizes the device. If not, move on to examining the port. Inspect it for debris, dust, or food. If anything is inside, shut down the computer and carefully remove the obstruction with a small instrument like a toothpick. If nothing is found in the port, the internal connection may be broken or loose. Test this by inserting the USB or HDMI connected device and move it around slightly. If the laptop connects to the device and then disconnects, or briefly recognizes it, the port or cable may be broken. If more movement is possible when testing the internal connection, the port may be detached or bent from its place in the laptop. In this case, it is best to take your laptop in to a professional.
If the above solutions did not work, try using any other HDMI or USB ports. Unplug from the port you are having issues with and test out others on the laptop. If the device starts working, the first port will need to be fixed for future use. Make sure to try out different cables with your computer. The cable may be broken rather than the port,
The cable-connected device could also be the problem rather than your laptop, Plug it into another computer and test if the device is recognized. If the USB device comes alive when plugged into a new computer, it is for sure the port that is the issue. Plugging a different USB device into your computer will also determine if it is the port or the device that is the problem.
Updating the system on your laptop may resolve the HDMI or USB port connectivity issue. For this Windows computer, first right click Start then left click Run. Next, type devmgmt.msc and click OK. This will open Device Manager Locate Universal Serial Bus Controllers in the list. Click the arrow next to the small cable so that it points down instead of to the right. Right click on the first USB or HDMI controller in the list, then left click on update driver option. Select search automatically for updated driver software. For each controller in the list, redo this process starting with right clicking on the list’s first USB or HDMI controller. After repeating these steps, restart your computer and check to see if your cable-connected device works.
Touchpad zoom not working
Zoom function does not change the size of view on computer screen.
Driver Update
Search for Device Manager in the search bar at the bottom left of the screen. Click on the mouse an other devices page. Select Update Driver and let he computer update.
Reinstall Driver
Search for Device Manager under the start menu. Right click the touchpad drive and select uninstall. Restart your computer and the driver will reinstall. Check the touchpad for any changes.
Touchpad Replacement
Contact Dell for parts and information on what to do with a failed touchpad.
Fix touchpad problems in Windows 10
Nicole May
crwdns2935283:002/14/20crwdne2935283:0
117 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
University of Alabama, Team S1-G3, Bedsole Spring 2020 crwdns2935289:0University of Alabama, Team S1-G3, Bedsole Spring 2020crwdne2935289:0
UA-BEDSOLE-S20S1G3
crwdns2936753:030crwdne2936753:0 61
crwdns2959996:0crwdne2959996:0 3,026
