crwdns2862637:0crwdne2862637:0
crwdns2869081:0crwdne2869081:0
Dell Latitude 5320 Not Charging When Plugged In
Is your Dell Latitude 5320 refusing to charge even when the adapter is plugged in? This guide breaks down the most common causes behind charging failures. Use this page to pinpoint what’s preventing your laptop from charging normally and find the right steps to get it charging again!
Damaged or Non‑Functional Charging Source:
Physical damage to the charger (such as frayed wiring, bent pins, or a loose connector) can prevent the laptop from receiving power. Try plugging in another device to see if the charger is working properly. If the other device does not charge too, the issue likely is not with your laptop, but rather with the charger you are using. Consider replacing it with a new credible charger.
System Glitches Preventing Normal Charging Behavior:
Occasional software issues can interfere with charging detection. A simple restart often clears temporary system errors and restores normal charging function. Use the Start Menu at the bottom of the screen on the end of the taskbar. Next, click the power button and select the Restart button.
Interference From Connected External Devices:
USB drives, cables, or any other external accessories can sometimes disrupt power management. Remove all external connections except the charger to check if the accessory is the cause of the issue.
Loose, Intermittent, or Physically Damaged Ports Preventing Stable Charging:
Wiggle the connector of the charger gently, if charging cuts in and out, the charging port may need cleaning or replacement.
Outdated System Software Affecting Power Management:
Make sure all Windows updates are complete by going to the Start menu on the taskbar and clicking Settings. In settings, go to Windows Updates and start any updates. You may need to restart your laptop.
Motherboard Charging Circuit Failure:
If the laptop turns on when plugged in but doesn't show an increase in battery percentage, the charging circuit on the motherboard could be failing. To fix this, the motherboard might need repair or replacement.
