crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Is your Dell Latitude 3420 running slowly? Use this troubleshooting guide to help diagnose why.
Too Many Background Programs Running
Users often leave multiple apps, browser tabs, or background tasks open at once. These use CPU and Memory, to fix this open the Task Manager (Ctrl + Shift + Esc) and check which program is are using the most CPU or memory, and close unnecessary tabs.
Insufficient RAM (Memory)
The Dell Latitude 3420 often comes with limited memory, which necessarily isn't enough for multitasking or modern applications. Upgrading the Laptops RAM to 16GB would significantly improve performance, To do this, remove the back cover and insert a compatible RAM stick in the open slot. This upgrade helps the system run faster and handle more tasks smoothly.
Outdated Software and Drivers
Old version of windows and device drivers can cause slow performance and compatibility issues. The solution for this is to run windows regularly and use Dell Support Assist to have it automatically check for BIOS and driver updates. Keeping everything up to date will have the laptop running efficiently.
Overheating
When the laptop starts to overheat, the CPU automatically lowers its speed to prevent overheating, this will make the system feel very slow and unresponsive. The solution is to clean the air vents and fans to remove all the dust build up that blocks airflow. compressed air would be ideal to remove the dust, and use the laptop on hard surfaces to prevent unneeded overheating.
Full or Failing Storage
When the storage drive is almost full, Windows has less space for temporary files. this will slow down the performance of the laptop, also if the drive is old it can also make response time on the laptop slower. The solution to this is to delete unnecessary files and empty and the trash bin, you can also run Disk Cleanup to clean up more storage. If these do not work simply upgrade to a Solid State Drive(SSD).
Sam Bradford
crwdns2935283:010/15/25crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Botvin Fall 2025 crwdns2935289:0UMass Dartmouth, Team 1-3, Botvin Fall 2025crwdne2935289:0
UMASSD-BOTVIN-F25S1G3
crwdns2942667:0crwdne2942667:0 272
