crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device will not power on
When you press the power button, your DYMO LabelWriter 450 does not turn on.
Device is not plugged in
Check that your LabelWriter is properly receiving power by making sure the power adapter is plugged in all the way into the back of the device.
Device is loose in wall jack
Check to make sure that your device is inserted all the way into the wall jack. The power adapter that comes with the LabelWriter ends in a large box, so it is possible that it may have come loose in the wall jack.
Device will not connect to the computer
Your computer will not recognize your DYMO LabelWriter 450.
USB cable is not the correct type
First, make sure you have a USB Type A to USB Type B cable (it comes included with your LabelWriter). The LabelWriter requires a USB Type B cable, so if you have misplaced the cable that came in the box, you will need to get another one.
USB cable is not properly inserted
Second, make sure the cable is securely inserted into the correct ports on both the device and your computer by inserting each end of the cable until they will not go any further.
Computer does not have the correct drivers
If your LabelWriter will still not connect to your computer, try downloading the corresponding drivers from the DYMO website by searching for 'DYMO LabelWriter 450' and clicking Support on its DYMO device page.
Poor print quality
Your DYMO LabelWriter 450 is printing faded labels or missing letters on the labels entirely.
3rd party labels
Labels that are not made by DYMO may not work with your LabelWriter. 3rd party labels may have different thermal sensitivity than DYMO labels, and the perforated holes on 3rd party labels may not be recognizable by the device. Make sure your labels are genuine DYMO LabelWriter brand labels.
Dirty print head
To clean the print head, first remove the label roll by lifting the lid and pressing the black-and-white eject button on the right-hand side of the device. Clean the print head and the bottom of the label roll with a small, soft brush or cotton swab.
Old or defective labels
It is also possible that the label roll in the device is old, or has become defective. To check for a defective roll, insert a different roll from a new box. If the new roll produces a print with no problems, it means that the old roll was old or defective.
Device does not respond to input
Your DYMO LabelWriter 450 is frozen, and will not respond to input and will not print.
Device is not responding
First, you can try unplugging the LabelWriter from the computer and the wall, waiting 10 seconds, and plugging it back in. It is possible that your LabelWriter is overloaded, and a restart of the device will solve the problem.
Software is unresponsive
Second, you can check your computer to see if the DYMO Label software is responding properly. To check if the software is responding, you can bring up the Task Manager (CTRL+ALT+DEL, or CTRL+Shift+ESC on Windows 10) on Windows or Force Quit (CMD+Option+ESC) on Mac. If the Label software is not responding, you can wait for it to start responding again, or quit the program and reopen it.
Computer is not recognizing device
It is also possible that your computer is not recognizing the LabelWriter. If you are certain that you have the correct drivers for the device installed on your computer, restarting the computer may solve this problem.
Labels are cut off
Your DYMO LabelWriter 450 is printing misaligned letters, and cutting off labels at the wrong points.
Preset size in software is incorrect
In the DYMO Label software, go to Preset Printing Sizes, and make sure your printing settings are matching the paper you currently have in your LabelWriter.
LabelWriter prints one or more blank, extra labels
Your DYMO LabelWriter 450 is releasing one or more blank, extra labels in between correctly printed labels as well as when the Feed Button is pressed. (Also applies to LabelWriter® 450 Twin Turbo).
Sensor Issue
This is typically an issue with the LabelWriter’s label sensor. Many users that have had this particular issue have had success in resolving it by simply reseating the sensor’s ribbon cable where it connects to the motherboard.
Jared Finkel
crwdns2935283:010/09/18crwdne2935283:0
676 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Leahy Fall 2018 crwdns2935289:0USF Tampa, Team S1-G4, Leahy Fall 2018crwdne2935289:0
USFT-LEAHY-F18S1G4
crwdns2944067:059crwdne2944067:0
Mine is just printing empty label after empty label as soon as I turn it on. I’ve emptied the print queue, rebooted etc but as soon as it has power it churns out label after label. This started happening after I cleared a paper jam.
l.love - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Using Windows 10, and my 4XL is just printing empty label after empty label (with garbage lines printed on) as soon as I turn it on. I’ve emptied the print queue, rebooted, reinstalled latest software, etc. but as soon as it has power it churns out label after label. Printer works perfectly on a Mac using iOS. Has cost me a lot of money in scrap labels!
Robert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
when I'm inserting the labels , the printer don't stop to rolling labels , what it's the problem ?
Andrei boss - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
when I'm inserting the labels , the printer don't stop to rolling labels , and don’t print the label. What it’s the problem. This the second time, the first time the machine was in guaranty, but now the machine have just 2 years..can you helping me with the problem. Thanks
alma stevenson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
No matter what I do the blue light never comes on!
Ivan Grajales - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 298
crwdns2959996:0crwdne2959996:0 65,104
