crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your DJI Goggles shut off by themselves after just a few minutes, here are some common causes and troubleshooting steps to fix the issue.
Dust and Debris
Dust can clog the vents for the fan and cause overheating.
  • Clear the vents and see if the problem resolves.
  • Make sure to clean the device after each use to prevent dust and debris buildup.
Firmware Out of Date
If the DJI Goggles have outdated firmware, this could potentially result in the device shutting off unexpectedly.
  • Update the firmware on the goggles and see if the issues are resolved.
Low Battery
You may have simply forgotten that you didn’t charge your device. There may be some battery left over that allows it to turn on briefly before shutting off.
  • Plug the DJI Goggles in for about an hour to let it reach full charge and try again.
Battery not Holding Charge
Maybe you didn’t forget to charge it but instead have a battery issue. Your device may have a faulty battery resulting in the battery draining quickly.
  • Check the power plug for dust and debris, which may prevent a solid connection.
  • If there is no dust or debris blocking the power cable from charging, you may have a faulty battery.
Lost Connection to Drone
This one is rare, but sometimes losing connection to the drone can cause the DJI Goggles to bug out and simply shut off.
  • Check your internet connection, which can disconnect you from the drone if it isn’t strong.
Levi
crwdns2935283:003/19/25crwdne2935283:0
51 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
UMass Dartmouth, Team 1-3, Rioux Spring 2025 crwdns2935289:0UMass Dartmouth, Team 1-3, Rioux Spring 2025crwdne2935289:0
UMASSD-RIOUX-S25S1G3
crwdns2942667:0crwdne2942667:0 387
