crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Will Not Power On
Your Creative Zen will not power on or respond and no display is shown
The Device Needs to be Reset
Use a paperclip to press the pinhole located next to the power switch and watch for a response on the display of the Creative Zen.
The Battery is Completely Dead
Plug the charger into the port and observe. A charging icon may appear. If the battery is completely dead then the icon may not appear. Check behind the play/pause button for a blue flashing led to indicate charging. It may take up to six hours. Wait for up to six hours and then try to power the device on. If this does not work reset by following the above instructions.
The Battery May be Bad
The battery will no longer hold a charge due to age or other factors and therefore needs replaced. See the battery replacement guide in the repairs section.
Will Not Charge
The charging icon does not appear on the display and the led behind the play/pause button does not flash.
The Charging Cord is Not Fully Plugged Into the Creative Zen
Push the charging cord into the charging port (the micro USB slot) firmly but not too forcefully as you do not want to break the device. You should feel it snap into place.
The Charging Cord is Faulty
Find or buy a new power cord either with an adapter wall outlet or with a PC USB
Trying to Charge a Fully Dead Battery With a PC USB
Use a wall power adapter. Be sure to check behind the play/pause button for a blinking blue led to indicate charging.
The Battery is Bad
No Audio
You are having trouble hearing sounds from the device
Loose Headphone Jack
If you see the screen working properly but no audio, check and make sure the audio jack is fully pushed into the ZEN Plus. Also, make sure the audio jack in plugged into the port that reads “aux”.
Volume button not on
Check and make sure the volume button on the ZEN device is high enough to hear. Some head phones have a convenient volume on/off button near the headphones, if so make sure the button is not on so the headphones are not muted.
Microphone doesn’t record
The microphone is plugged in but nothing gets recorded
Loose microphone jack
The microphone jack may not be pushed in all the way. Also, be sure the microphone is plugged into the “line in” port of the device.
Microphone is plugged in but no recording
The microphone being used might be defective, if another microphone is available, plug in and test a different microphone to see if the device is defective or the microphone.
Blank screen
The screen is dark to where you can’t see anything
Power on but screen is dark
The device might have a dead battery and needs recharging, make sure that the charger is plugged into the power source as well.
The joystick and/or buttons do not work
The buttons to operate the device are not functioning
The device may be frozen
The device maybe frozen and needs to be reset. Try placing a small paper clip in the pinhole on the side of the device.
Kelsea Weber
crwdns2935283:011/12/15crwdne2935283:0
21 580 crwdns2915208:0crwdne2915208:0
crwdns2935297:032crwdne2935297:0
iFixit, Team S1-G1, Weber Summer 2018 crwdns2935289:0iFixit, Team S1-G1, Weber Summer 2018crwdne2935289:0
FIX-WEBER-SU18S1G1
crwdns2935297:0396crwdne2935297:0
crwdns2944067:06crwdne2944067:0
my problem is that my zen keeps tripping out
andy.towning - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a blue light beside the head phone jack port. Copies and plays ok, screen is not functioning, but what is the blue light saying to me?
Frank Wellwood - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Dang, i have the same thing, got the lil blue light but the screen well, its just black
Mitchel Go - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Headphone jack on my Creative Zen Touch is not working. Worth it to try and get it repaired or replaced?
Michele Mancione - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Screen is just black, managed to make it work a week ago by resetting it multiple times.
Yet the screen just stays black sometimes when you close the device.
Today as i wanted to check my device real quick the screen stood black as usual, managed to get in but only for a short time has it turned black again while i was on the "image" section were it was the last time before closing it (a week ago).
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 95
crwdns2959996:0crwdne2959996:0 16,850
