crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Headphones don't connect with your mobile device
When trying to connect using bluetooth the device will not pair with your mobile device.
Headphone cables connected
Disconnect the back-up audio cable and disconnect the USB charging cable. Having headphones connected might be preventing the Bluetooth from connecting. Attempt to connect again without any other cables connected to the headphones.
Incorrect Bluetooth setup
On your mobile device, disable the Bluetooth feature and then re-enable. Delete your E7 from the Bluetooth listing on your device. Move your mobile device closer to the headphones and away from any interference or obstructions. Attempt to connect with another mobile device.
Bad Bluetooth connection
If the Bluetooth signal is weak, out of range, or if there is interference the connection may fail, or the sound will cut in and out.
Signal interference
Please move away from any other devices or obstructions. This includes barriers such as walls and any other wireless transmitters, Bluetooth headphones, and/or devices that are distanced less than 15 meters. You may need to move your mobile device closer to the headphones. Try to connect again.
Low battery power
Recharge the battery and check if the network signal is OK (whether the player is buffering). Having low battery power will reduce the strength of your Bluetooth connection.
Bluetooth software outdated
If the headphones and the Bluetooth device are not compatible via consistent issues with the headphones, your version of Bluetooth might be outdated. Make sure you have downloaded the most recent software update for your mobile device or have updated your drivers to the latest update on your computer.
No sound
When attempting to play audio through the headphones there is little to no sound.
Device isn’t on
Power on the headphones. If the headphones do not power on, charge the battery. Increase the volume on your headphones, your mobile device, and music source. If you are unable to adjust the volume on the headphones, or the volume button is stuck, you may need to replace the volume button.
No music signal
Make sure you are connected to the correct device by checking your Bluetooth on your phone and checking connected devices. Make sure the device is within proximity of the headphones. Move your mobile device closer to the headphones and away from any interference or obstructions. Use a different music source and try to connect a different mobile device. The problem might not be the headphones but the device that is trying to connect.
Battery won't charge
The headphones are having issues with basic functions such as staying on, connecting via Bluetooth, producing audible sound.
Bad power source
First secure the ends of the USB charging cable. If this doesn’t work, try another charging source as it might be just a problem with the electrical outlet. If your headphones have been exposed to high or low temperatures, let the headphones return to room temperature and try charging again. If these methods do not work, you may need to replace the battery.
Noise canceling function doesn’t work
When the headphones play audio and noise canceling is enabled, there is little to no difference in sound quality.
Noise canceling is off
Make sure that the noise canceling function is turned on. Slide the noise canceling function button to the “NC” position. The noise canceling button is located on the bottom of the right ear piece.
Worn out ear cushions
Adjust the ear cushions to fit your ears. If the ear cushions are loose, reset the ear cushions. If there is damage to the ear cushions allowing noise to escape, you may need to replace them.
(Info point) The noise canceling function is effective in low frequency ranges such as airplanes, trains, offices, near air-conditioning, and is not as effective for higher frequencies, such as human voices.
Jacob Burrer
crwdns2935283:003/26/22crwdne2935283:0
463 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Mellen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 2-2, Mellen Spring 2022crwdne2935289:0
UMASSD-MELLEN-S22S2G2
crwdns2944067:035crwdne2944067:0
When I connect my volume on my chrome os cant be altered. no matter how low or high i put it, it stays the same volume. I have to adjust on the site im listening to things on for it to work, and its not a problem with the computer because when i disconnect it alters.
Phoebe Cannon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
what is the default pin code to pair
Kevin Quinn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
According to the manual it's 0000
neurot5 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The right ear of the headphones are not working. It’ll glitch out and it will cut out and there will be no audio through the right ear.
Charlotte Oshea - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same with me. My left year of the headphones started to glitch out and it no longer produces any sound on that side.
Adix Le - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 180
crwdns2942667:0crwdne2942667:0 24,892
