Contixo V9 Troubleshooting
Released October 19, 2023, identified by model number X002NK7077
Frozen Screen
The screen is unresponsive to touch, or button use. Use the {Display Assembly Guide} to fix the screen.
Damaged Motherboard
It could be possible that the motherboard is damaged. This could be due to dropping the device, exposure to liquid, or severe temperatures. To replace this, you'll have to follow a {Motherboard Replacement Guide}.
Outdated OS
You may need to update the software on the device. Outdated software typically will make the device run slow, lag, or will result in a frozen screen.
To update the software on the device, follow these steps:
  • Step 1: On the tablet, navigate to the Settings app.
  • Step 2: Scroll to the System tab then click on it.
  • Step 3: Click on Advanced, this will open up more options allowing you to click on System Update.
  • You will be brought to another tab. This tab should tell you if your device is in need of an update or not, but you can click Check for Update to be sure. Remember to be connected to Wi-Fi so the device can check for or be updated properly.
Weak Wireless Connection
The Wi-Fi may disconnect and reconnect abruptly or may not appear when prompted for connectivity.
Outdated Software
Outdated software can result in connectivity issues. Your device may need a software update to maintain the quality of performance.
Distance from Router
If your provider doesn't appear when prompted it may be because you're too far away from your router. Try moving closer to increase the strength of your connection.
Distorted Audio
The quality of the audio is unclear and quite hard to comprehend.
Aged Speaker
With the speaker aging over time, it could become oxidized causing a scratchy sound when controls and audio is used. Use the {Speaker Replacement Guide} to restore sound quality.
Dirty Speaker Ports
The speaker ports could have a buildup of lint, dirt, and even liquid which could cause the speaker not to function correctly. Try cleaning out the speaker ports to produce a clearer sound, using a toothpick or a Q-tip.
Unsecure Camera
The camera lens may fail to stay secure or appear unclear/blocked.
Issues with the Camera App
Try resetting the camera app by clearing its cache and data. If that doesn't work allowing permissions in the app's settings could restore its function.
Positioning of the Lens
Ensure the lens aligns with the space provided for it. Use the {Camera Replacement Guide} to help you secure your camera.
Short-term Battery Life
The tablet shuts down or dies sooner than expected. Use the {Battery Replacement Guide} if there's an issue with the battery.
Charging Port Issues
If your computer is charging very slowly it could be that there is debris inside of the charging port. Try using a toothpick or Q-tip to clean out the port.
Outdated Software
Battery drainage challenges may be linked to outdated software. When utilizing Contixo V9, you may look for updates.
Rose Mapua
crwdns2935283:009/12/23crwdne2935283:0
269 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-4, Coppersmith Fall 2023 crwdns2935289:0University of North Texas, Team 3-4, Coppersmith Fall 2023crwdne2935289:0
UNT-COPPERSMITH-F23S3G4
crwdns2935297:048crwdne2935297:0
crwdns2942667:0crwdne2942667:0 559
