Choosing a Video Adapter
Years ago, Proctor & Gamble, RJ Reynolds, and other consumer products giants discovered that the best way to increase their sales was to go into competition with themselves. Instead of making only one or two brands of laundry detergent or breakfast cereal or floor wax or cigarette, they started making dozens of brands, all similar, but each appealing to a different type of buyer. Just as important, the flood of brands meant the giants could stifle competitors by monopolizing scarce retail shelf space.
The two major video card makers, ATI and NVIDIA, have taken this scheme to ridiculous extremes. Each produces two dozen or more video chipsets, from old, slow models that are used in $20 video cards to models that are used in $700 gaming cards. Any particular chipset may be available in variants that run at different clock speeds, and any of these may be used to build video adapters with different amounts, types, and speeds of memory, and so on. Many different companies use ATI and/or NVIDIA video chipsets to build their own branded video cards, further increasing the number of choices and the level of confusion. (When we checked NewEgg.com while writing this paragraph, we found an incredible 569 different video cards for sale 238 PCIe, 283 AGP, and even 48 PCI models.)
We were about to say that even we can't keep everything straight, but in fact it's worse than that. Based on conversations with some of our contacts at ATI and NVIDIA, we don't think they can keep everything straight. So which video card should you buy? Here are some guidelines:
Decide how much to spend.
If you don't play 3D games, 3D graphics performance doesn't matter, unless you plan to upgrade to Windows Vista. Any current video card, even a $35 model, is fast enough to run productivity software and similar 2D applications under Windows XP or Linux.
If you're a casual gamer, spending $75 to $100 buys you much faster 3D graphics performance. If you're a serious gamer, plan to spend at least $150 to $250 to be able to play recent games at reasonable frame rates. If you're a rabid gamer, well, the sky's the limit.
If you are upgrading a system to be compatible with Windows Vista, choose a card with at least midrange 3D graphics performance, something like an NVIDIA 6800GT or better with at least 128 MB of video memory.
Consider a motherboard replacement.
Rather than replace a failed video card or integrated video, consider spending a bit more to replace the motherboard instead. The integrated video on current motherboards is more than sufficient for anything other than gaming (or Vista), and by replacing the motherboard you also get a newer chipset, a new BIOS, new features such as SATA, and a new motherboard that has a warranty and will probably last for years.
Don't overbuy.
If you buy a standalone video adapter, remember that video is just one part of your system. It makes no sense to buy a fast gaming video card for an older system. You'll see some video performance benefit, certainly, but the card can't reach anything near its real potential when hampered by the relatively slow processor, memory, and other components in the older system. Other than for gaming or to add extra features, such as TV capture, we recommend spending no more than $50 on a video adapter to upgrade an older system.
Buy only a Universal AGP 3.0 or PCI Express x16 video adapter.
If you decide to install a standalone video adapter, buy only a Universal AGP 3.0 or an x16 PCIe adapter. Check the motherboard manual to verify which type or types of adapter it supports, and then buy accordingly. Most recent AGP motherboards use either 0.8V AGP 3.0 cards only or 1.5V AGP 2.0 and 0.8V AGP 3.0 cards interchangeably. Fortunately, the PCI Express standard has not yet fragmented, so any PCIe adapter works with any PCIe motherboard.
Unless you are a gamer, give more weight to 2D display quality than to 3D performance.
Display quality is subjective and very difficult to quantify, but a real issue nonetheless. Matrox video adapters have always been the standard by which we judge 2D display quality, but Matrox adapters are no longer competitive in terms of 3D performance. The three major video chipset companies are ATI and NVIDIA, both of which provide chipsets that are used both for standalone AGP adapters and for embedded video, and Intel, whose video adapters are available only in integrated form. ATI and Intel video adapters have always provided excellent 2D display quality just a half-step behind Matrox so we don't hesitate to recommend either of those brands to anyone who is concerned about 2D quality. Older NVIDIA adapters, especially high-performance models, often favored 3D performance at the expense of 2D image quality. NVIDIA 6000-series and later video adapters have excellent 2D display quality.
If you buy a high-performance video card, make sure it has a good warranty.
Video cards used to be among the most reliable components of a PC. This is changing, not because manufacturers are cutting corners, but because new high-performance video cards are pushing hardware technology to the limit. Having a video card die after only six months or a year is now relatively common, particularly for those who push the card past its limit by overclocking it in pursuit of the highest possible performance. We've seen video cards with 90-day warranties, which is completely unacceptable. Regard one year as an absolute minimum, and longer is better.
Make sure that the video adapter supports the display settings you need.
Video adapters differ in the resolutions and refresh rates they support. It's important to make sure that the video adapter you buy supports resolutions and refresh rates appropriate for your display.
Resolution
Resolution describes the maximum number of pixels the adapter can display, horizontally and vertically. For example, an inexpensive display adapter may support resolutions of 640x480 (640 pixels horizontally by 480 pixels vertically), 800x 600, 1024x768, 1280x1024, and 1600x1200. If you have a large CRT monitor that supports 1920x1440 resolution (and you use that resolution), the maximum resolution of this video card is too low to be optimum for your monitor. Not all video adapters support all intermediate resolutions. For example, although the adapter we're discussing supports 1024x768 and 1280x1024, it may not support the intermediate 1152x864 resolution. If you have a display that is optimized for that resolution, you may want to look for a different video adapter that also supports 1152x864.
Refresh rate
Refresh rate is the number of times the image is renewed per second. If the refresh rate is too low, the image on a CRT monitor flickers. (Flat-panel LCD displays operate at low refresh rates without flickering.) The minimum refresh rate necessary to avoid flicker depends on many factors, including the phosphors used in the monitor, the size and resolution of the monitor, ambient lighting conditions, and your own vision. Most people consider 72 Hz the minimum acceptable refresh rate on small to midsize CRT monitors, and 85 Hz is better. On large CRT monitors, a 100 Hz or higher refresh rate may be necessary to avoid flicker. The maximum refresh rate supported by a video adapter is related to the resolution you use. For example, a particular video adapter may support a 120 Hz refresh rate at 1024x768, but only 85 Hz at 1280x1024 and 60 Hz at 1600x1200. Despite the fact that the adapter technically supports 1600x1200, most people will find the 60 Hz refresh rate unacceptable, so in practical terms that adapter is limited to 1280x1024.
Make sure the video adapter provides the interface(s) you need.
Most analog CRT monitors use the familiar high-density DB15 VGA connector, although a few high-end models also support RGB component video. Flat-panel displays (FPDs) use a variety of connectors, including the analog VGA connector (typically used by low-end FPDs), or one of three different types of DVI connectors described earlier in this section. Midrange and higher FPDs normally provide a DVI-D or DVI-I digital connector, and may also provide a DB-15 analog connector. If you plan to run dual displays, make sure the video adapter you choose has dual connectors of the type(s) needed by your displays, and that those connectors can be used simultaneously.
More about Video Adapters
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
478,474 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2935297:072,612crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 3,192
