Casio won't turn on
The camera will not turn on.
Drained/Bad battery
If your camera cannot turn on check to make sure the battery is charged. If the battery will not work in another camera you should consider purchasing a new one.
Power button stuck
If there is debris or the button stuck it might not work effectively, click the play button to see if it will turn on camera LCD screen. Then click on the record button to switch over to shoot mode.
LCD screen does not work
The LCD screen does not work correctly.
The screen will not turn on
Check to make sure the battery is charged.
Screen is cracked
If the screen is cracked you can replace it by using the repair guide featured on the Casio page.
Issue with the lens
There is a problem with the camera lens.
The lens will not retract
A common problem with cameras is that there might be debris (like sand or dirt) that is stuck in the lens. There are many ways to fix this problem
1. Take out the battery, wait 5 seconds, then reinsert it.
2. Use a compressed air gun to try and blow debris out of the lens
3. NOTE: USE AS LAST RESORT Try and use something like skinny and small to pry the camera shutter open while hitting the power button. This can damage the camera if done harshly so use with caution.
The flash will not work
The flash on the camera will not activate
Low Battery
If the battery on the camera is close to running out the flash may not work to full effect. Try charging the battery
Software Glitch
This camera has a software glitch that may needed to be solved with a reset. Change the camera to any mode EXCEPT "No Flash". Then take out the battery, wait 5 seconds, and then reinsert to the camera.
Flash Issues
The flash on the camera may be damaged or burned out. Check the Casio repair guide to fix it.
Christian
crwdns2935283:001/28/11crwdne2935283:0
320 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-38, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-38, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G38
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 70
crwdns2959996:0crwdne2959996:0 8,432
