If you have just bought a new canon printer and suddenly you are receiving a Canon printer not responding error notification then this article help you for fixing this.
Check Connection
To start with, check your internet connection and check if the printer is associated with a working force source appropriately. Ensure the association is legitimate. Additionally, ensure there are no punched wires and the gadget's attachment is spotless.
Check WiFi Connection
On the off chance that you are utilizing a WiFI Canon printer, ensure you have associated it to a nearby Wifi system. You can go to your PC's settings to check if the printer is associated with your wifi organize or not. In the event that your PC and the printer is associated with a switch, check if there is a constant power supply.
Device and Printer
After checking all requirement check , we should get into the software part
  • Snap the Start catch and go to Control panel.
  • From the Control board, discover Devices and Printers. In the new window, you can see the gadgets associated with your PC.
  • Check if the Canon printer is available in the rundown of those dynamic equipment gadgets. Your printer will be shown on-screen with the model number, for instance Canon MX 920 printer, Canon MG 2920 Wireless Printer and so forth.
  • You should check on the off chance that the printer is associated legitimately in the event that not, at that point click on Add a printer choice present at the base bar
  • Next, experience the setup procedure
Much the same as each other equipment, your printer has a driver as well. In the event that you can see the printer in the equipment list, select it and open Properties.
  • In the properties window, go to DRIVERS
  • Here you will get the subtleties of the Driver variant. You have check if the driver is refreshed or not. In the event that it's obsolete, if you don't mind refresh the driver.
  • Check for the accessible updates in the window
  • Inside the printer bundle, you can get the minimal plate or album with maker's name and model number
  • Addition the plate into your PC and complete the SETUP physically. Additionally, you can give the setup wizard a chance to play out the procedure bother free
Check Print Queue:
You can see your printers exercises from here. To check the print line play out these means:
  • In the search bar of your task bar, look for 'gadgets and printers'
  • Snap on the Devices and Printers choice and discover your printer in the rundown
  • When you have discovered the printer, press and hold the right-click on your printer to see its exercises
  • On the off chance that you see an improvement that ought not be in the line, you can undoubtedly stop or drop the advancement. In the event that you need, you can likewise clear the entire print line and begin with your new prints too.
Sofia james
crwdns2935283:011/22/18crwdne2935283:0
165 crwdns2915208:0crwdne2915208:0
crwdns2944067:012crwdne2944067:0
None of this is working for me!
verahippo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Brand new printer, will not print. Just keeps Queing print jobs which I keep deleting
how do you put the back onto printer pixma MX722
ekeller585 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I had a paper jam. message said in rear of printer so I removed the back cover and cleared the jam.  Now I cannot get the back back on.
The cover has an arrow on it ! Put it on and push right!
Dan Shepski - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 158
crwdns2942667:0crwdne2942667:0 7,492
