crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
What type of memory card does the Canon SX280 HS operate with?
The DS Card must be inserted properly. Do not force the SD Card into the slot.
It is capable of using all standard SD Card.
Why will the flash not open?
When the flash does not appear then there are three possibilities.
1). The flash was blocked by a digit when the camera was powered on.
2). The battery is not carrying enough charge power to extend the flash up.
3). The flash setting is turned off.
Photos will not save to camera's internal memory or memory SD card
Make sure the proper memory card is inserted fully, facing the correct way and locked into place.
How to dislodge stuck lens shutters?
The battery may not have enough charged power to open shutters.Also there may be dirt and sand particles in between the shutters.
Why won’t the camera take a focused picture?
The settings may be altered. Make sure to turn dial to the auto setting.
The LCD monitor will not display an image
Check the battery power, if not the back light may be dimmed, or the screen in damaged.
Geoff Wacker
crwdns2935283:009/30/13crwdne2935283:0
93,042 crwdns2915208:0crwdne2915208:0
crwdns2935297:088crwdne2935297:0
crwdns2944067:05crwdne2944067:0
My lens is stuck open a little sliver and camera will not turn on. What can I do?
Cherryl Lowry - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My camera’s screen isn’t turning on but the lense will open and when I hit the shutter it will make the noise like it is taking a photo
Mister D - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My camera will not charge. It’s been dead for over a year. Doesn’t this camera have a light that shows when it’s charging?
Micheal Logan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
why does the Memory Card locked notice come on the screen
butch_k56 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 2,292
