crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Time and date settings do not stay set
The time and date stamp need to be reset every time the camera is turned on. A notice may appear to change the batteries even after the main batteries are replaced.
Lithium ion battery (CR1220) is dead
The lithium ion battery is a CR1220 model. Use this replacement guide for steps on how to change this battery.
Camera does not turn on
Power button has no response when used.
Batteries are dead
Replace dead batteries with new ones.
Battery door does not latch closed
Make sure the battery door closes tight and that nothing is blocking the door from closing. If the door will not latch closed use this replacement guide for changing the battery door.
Internal components are damaged
Open the body of the camera and do a visual inspection of the connections and parts in the camera. Make sure and plugs or adapters are snug. See the tear down guide here for opening the body of the camera.
LCD screen is non-operational
Control knob does not activate LCD screen when turned to the correct settings.
Batteries are dead/weak
Replace bad batteries with new ones.
LCD screen adapter connections bad
Open the body of the camera and the LCD screen compartment and check for loose connections.
LCD screen broken
If this does not rectify the problem the LCD screen should be changed following this replacement guide.
The camera will not zoom in
The picture is blurry and none of the buttons or manual zoom operations work.
Zoom mechanism is dirty
Dirt and grime can build up in the zoom mechanism. The mechanism can be cleaned following the manufacturers cleaning instructions. Use the tear down guide here to access the internal components.
Zooming mechanism is broken
If the mechanism is still not responding a new zooming lens can be installed.
Zoom buttons are broken
Open the body of the camera and make sure there is no damage to the area near the zoom buttons. Check the connections and replace any damaged parts.
Dial control does not change the settings
The settings do not change when the dial control is operated.
Dial control connections are dirty
Open the body of the camera and check the connections around the dial. Clean gently if necessary, making sure the connections are not damaged.
Dial/connectors broken
Open the body of the camera and change the dial and connectors if there is damage.
Camera does not connect to tripod
Tripod will not screw into the adapter on the bottom of the camera.
Tripod has stripped treads
Use a different tripod.
Adapter opening is blocked
Clean the opening of the adapter with small tool. Make sure to not damage threads.
Tripod adapter is stripped/broken
Change the tripod adapter on the camera. Use this replacement guide to make the repair.
Paul Spillan Jr
crwdns2935283:004/04/19crwdne2935283:0
285 crwdns2915208:0crwdne2915208:0
Oregon Institute of Technology, Team S2-G6, Lancaster Spring 2019 crwdns2935289:0Oregon Institute of Technology, Team S2-G6, Lancaster Spring 2019crwdne2935289:0
OIT-LANCASTER-S19S2G6
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 2,429
