crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Canon PowerShot SD1300 IS Troubleshooting
This troubleshooting page will help you diagnose issues with the Canon PowerShot SD1300 IS.
Insufficient Battery Performance
Your battery will not hold a charge
Faulty Battery
Plug in a power adapter and try to power the camera on. If the camera will power on while plugged into the adapter and not while mobile then the battery is faulty. See repair guide for Canon PowerShot SD1300 IS Battery Replacement.
Faulty Power Adaptor
To test power adapter, plug camera into the wall. If the camera does not show it is being charged then see repair guide for Power Adapter Replacement.
Lens not Retracting
If your lens does not expand when zooming out or in or powering on.
Faulty Lens
Turn on the camera and observe the lens. If your lens is not retracting or expanding try to see if it will work when using the zoom feature. If the lens is still not expanding or retracting or you see an E16 error message on the screen then see repair guide for a Faulty Lens.
Insufficient Shutter Speed
Pictures appear to be distorted then the shutter is not capturing the picture properly
Faulty Shutter Motor
Turn on the camera and try to take a still picture. If the picture is not being captured, big glare in picture, or blurry picture then see repair guide for a Faulty Shutter Motor Replacement.
Miscalculation of Aperture
If image appears to dark, too white, dots on image, rough, or grainy then there is a Miscalculation of Aperture.
Faulty Motherboard
Adjust the brightness and exposure compensation, adjust the image with the eye contrast, and adjust the flash and ISO speed. If changing these settings still result in rough or grainy images then consider replacing the motherboard.
Unresponsive Shutter Button
Shot cannot be taken even though shutter button is pressed fully.
Faulty Shutter Button
Set the [IS mode] to [Continuous] and set the flash to [H]. Increase the ISO speed and attach camera to a tripod. If image still does not show up on the screen when the shutter button is pressed then consider replacing shutter button. See repair guide for Faulty Shutter Button.
Dirty Shutter Button
If the button appears to be sticky then there is dirt or debris under the shutter button needs to be cleaned. See repair guide for Dirty Shutter Button .
Clayton
crwdns2935283:003/20/17crwdne2935283:0
584 crwdns2915208:0crwdne2915208:0
Texas Tech, Team S13-G1, Bennett Spring 2017 crwdns2935289:0Texas Tech, Team S13-G1, Bennett Spring 2017crwdne2935289:0
TTU-BENNETT-S17S13G1
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,356
