CPU Troubleshooting
In one sense, there's not much troubleshooting to be done for a processor. A properly installed processor simply works. If it stops working, it's dead and needs to be replaced. That seldom happens we're tempted to say "never" unless the processor incurs lightning damage, is the victim of a catastrophic motherboard failure, or overheats severely (usually from misguided attempts at overclocking, or running the processor faster than its design speed). A processor in a system with a high-quality motherboard and power supply that is protected by a UPS or a good surge protector is likely to outlast the useful life of the system.
In recognition of the primary danger, modern processors incorporate thermal protection, which slows down the processor or stops it completely if the temperature rises too high. Even if the processor isn't throttling throughput, operating it at a high temperature can reduce its life. Accordingly, it's important to monitor processor temperature, at least periodically, and if necessary, to take steps to improve processor cooling. If your system slows down for no apparent reason or hangs completely, particularly in a warm environment or when the processor is working hard, it's quite possible that overheating is responsible. Here are the most important steps you can take to avoid overheating:
Keep an eye on processor temperature.
Use the motherboard monitoring program, or reboot the system, run BIOS Setup, and view the temperature and fan speed section. Take these measurements when the system has been idle as well as when it has been running under heavy load. It's important to do this initially to establish a "baseline" temperature for the processor when it is idle and under load. You can't recognize abnormally high temperatures if you don't know what the normal temperature should be. If you run the motherboard monitoring program, set reasonable tripwire values for temperatures and configure the program to notify you when those temperatures are exceeded.
Keep the system clean.
Blocked air vents can increase processor temperature by 20 C (36 F) or more. Clean the system as often as is necessary to maintain free air flow. If your case has an inlet air filter, check that filter frequently and clean it as often as necessary.
Use a good CPU cooler.
CPU coolers vary greatly in efficiency (and noise level). Although the CPU cooler bundled with a retail-boxed processor is reasonably efficient, replacing it with a good aftermarket CPU cooler can reduce CPU temperature by 5 to 10 C (9 to 18 F). Make sure that the processor surface is clean before you install the CPU cooler, use the right amount of a good thermal compound, and make sure that the heatsink is clamped tightly against the processor.
Install supplemental case fans.
In particular, if you've upgraded the processor or installed a high-performance video adapter, it's possible that you've added more heat load than the case was designed to handle. Adding a supplemental fan, or replacing an existing fan with one that provides higher air flow, can reduce interior case temperatures dramatically, which in turn reduces processor temperature.
Upgrade the case.
In most systems, the processor is the major heat source. A TAC (Thermally Advantaged Chassis) case provides a duct (and sometimes a dedicated fan) to route waste CPU heat directly to the outside of the case, rather than exhausting it inside the case. In our testing, using a TAC-compliant case routinely lowered CPU temperatures by 5 to 10 C (41 to 50 F) relative to running that CPU in a non-TAC case.
You can buy a TAC case, or, if you're handy with tools, turn your old case into a TAC case. To do so, simply use a 2' to 3' hole saw to cut a hole in the case side panel directly over the CPU. Make a duct of the appropriate length using cardboard or plastic tubing, and secure the duct to the case with screws or adhesive. If you want to be fancy, you can install a standard case fan between the interior panel wall and the duct.
Position the system properly.
As amazing as it sounds, changing the position of the case by only a few inches, and in some pretty non-obvious ways, can make a major difference in system and processor temperature. For example, Robert's main office system sits on the floor next to his desk, directly in front of a heating vent. During the summer, when the air conditioning is running, that processor routinely operates 5 C cooler than during the winter months, when Robert closes the vent to prevent hot air from blowing on the system. That might seem reasonable, until you realize that the cool air from the vent is blowing on the back of the system, which has only exhaust fans. The ambient room temperature is actually lower during winter months and the ambient air is what's being drawn into the system so we'd have expected the system temperature also to be lower in winter.
Despite the odds, processors do sometimes fail. If you are reasonably certain that your processor has failed, the only practical way to troubleshoot it is to install the problem processor in another system or to install a known-good processor in the problem system. The former is the safer choice. We have never heard of a failed processor harming a good motherboard, but a catastrophically failed motherboard that has killed one processor could easily kill another. For that reason, if we're convinced that a processor is bad, we always pull it and test it in another system.
More about Computer Processors
crwdns2935291:0crwdne2935291:0
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
478,949 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072,954crwdne2935297:0
What is the proper arrangement for this CPU installation?
1. Install the cooling system.
2. lower the release lever arm
3. holding the CPU by its edges, position it over the socket.
4. lift and release the lever arm
5. Locate the orientation mark on the corner of the CPU and socket.
leizl_zione - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
3, 5, 2, 4, 1 is the correct order for installing a CPU I believe.
Sarathchandran AR - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have two processors that are not working.No signals,no fan spinning and light off.I I need both of them to start again.
Please any idea help?
Your advice will be appreciated.
Thankyou.
Kevin
Learning Technician
Kevin Jerry - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 150
crwdns2959996:0crwdne2959996:0 73,507
