crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your CAT S62’s battery charges very little over long periods, follow this page for possible solutions.
Debris in Charging Port
crwdns2944686:0crwdne2944686:0
Do not blow into the port! Moisture can easily damage the functionality. Additionally, do not use any metal tool to clean the port.
  1. Turn the device off fully.
  2. Carefully blow compressed air into the port. Avoid placing the straw piece of the compressed air directly into the port.
  3. Insert a small, non-metal tool inside the charging port (such as a toothpick) and gently move it around inside the port. Pull it out often to clean out any debris that may have been loosened.
  4. Once clean, power on the device and continue using/charging it as normal.
Faulty Charging Cord
If a charger/power cord is old, damaged, or corroded, it may affect the charging speed or power. Also, if the power source, such as a wall outlet, is damaged or not working properly, this could instead be the cause. Change out the charging cable, power adapter, and which outlet you're using.
Background Apps are Draining Battery
Method 1: Close recent apps
  1. Tap the square button on the bottom right of the screen.
  2. To close one app, swipe up on its thumbnail.
  3. To close all apps, find an option such as "Clear all" or "Close all," and then tap it.
Method 2: Force stop an app
  1. Go to Settings.
  2. Tap on Apps & notifications.
  3. Tap See all apps.
  4. Scroll down and select the app you want to close.
  5. On the App info page, tap "Force stop" and confirm by tapping "OK".
Outdated Software
  1. Open the Settings menu. You can do this from the home screen by swiping up to view all apps, then finding and tapping the "Settings" icon.
  2. Scroll down and select "System".
  3. Tap on "Advanced" in the System menu.
  4. Select "System update".
  5. Tap "Check for update" or wait for the phone to automatically begin searching for available updates.
  6. Follow the on-screen instructions if an update is found.
Exposure to Extreme Temperatures and Direct Sunlight
High temperatures put stress on the battery and internal components, potentially leading to slower and worse charging quality. Keep the device out of direct sunlight and hot areas.
Aging battery
Phone batteries degrade over time and with device usage. If all else fails, seek professional assistance in replacing the physical battery.
Cassandra Schrammen
crwdns2935283:009/09/25crwdne2935283:0
725 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-1, McMurrin Fall 2025 crwdns2935289:0Utah Tech University, Team 1-1, McMurrin Fall 2025crwdne2935289:0
UTAHTECH-MCMURRIN-F25S1G1
crwdns2936753:030crwdne2936753:0 58
crwdns2959996:0crwdne2959996:0 493
